| 99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only. |
I have a 2003 Excursion PSD 7.3 4x4. My problems is that when I reach about 40 mph thru 60 mph. It gets obnoxiously loud inside. It really hurts your ears. At first I thought it was in need of a tire rotation and balance but that didn't work. Today I had the wheels aligned but that did not work. I don't know what to do now. The noise does not happen when I am below 40 and above 60. The noise is much like when a window is down and you are driving down the road and it hurts your ears. Back a few months ago I hear some squeaking when backing up, I was thinking it came from the rear differential drive shaft bearing but it stopped. Does someone have advice?
I dont have a clue man... is the engine loud are the tires loud.. u know ect ect.. elaborate. doe anything sound broken? is performance affected?
If it was something in the driveline I would think you would have a vibration as well as the noise. Is it a highpitched squeak, constant whistle, need more info before I can help you out.
No performance issues, no real loss of fuel milage. I looked at the tires there is some where on the inside but the shocks are good and I had a wheel alignment. It is not the engine, I know that for sure. It has to do with something being out of balance or something - It is the only thing I can think off. I am pretty good with engines so I know it is not that.
My guess, wheel, chasis, differential, transfer. - Only thing I can think of. I am stumped on this one. It started after I took it camping and was going over "wash-board dirt roads". |
It is not high pitched, more of a low vibration sound but you don't feel the vibration perse, but you can definately hear it.
maybe rotate your tires... uhhhhh... balanced again maybe. maybe u knocked something those on the washboards. they can be pretty rough.
Check your U-joints on the rear driveshaft and check the carrier bearing ( driveshaft bearing). As those maybe getting wore out and this sounds like the early signs of failure.
yeah. what he said. lol I dont know man. I dont know how to fix things until they break. When they do... it doesnt bother me as long as its close to home
Also check your wheelbearings on your front axle as well.
I had heard squeaking when backing-up a couple months back coming from the rear differential. If the U-joint could cause this. I think I will start there. Seems to be a reasonable place to start. Thank you guys for your help.
By the way Big Country - Thanks for your service to the Country - my brother is in Iraq right now. |
