| 99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only. |
Electrical problems after it rains???
Lately on my 2000 powerstoke Ex after it rains multiple dummy switches stay on, airbag, abs, service engine soon, overdrive light flashes and speedo stops working but only after it rains, it happened earlier this summer after a rain but after a couple of sunny days all was fine, now its happening again after this rainy weekend...help...help...help
Driver side of windshield can leak onto PCM and/or fuse block.
I also have the chime that let's me know I left the keys in the ignition or lights on going off even with the keys out but only with the drivers door is oven, time on the radio and pw & pl lights staying on after its closed and lock up too, you think water in the pcm and or fuse block can be the problem? Guess it makes sense, I'll have to check it out on my next day off. Any body else experience this???
I think that's the door sensor. Mine does it too sometimes. Or did. Lights would stay on when all doors were shut.
You guys ever find the culprit? I have some wierd radio and power window probs happening too. Just wondering if there is some famout Excursion short circuit problem I don't know about. All my problems have been on the driver's side.
I tightened up the battery connections and it has seemed to have cleared up but it hasn't rained in a while either so not sure if the problem is going to come back, we'll have to wait and see???
I remember something about the GEM module getting wet and causing all sorts of weirdness.....could be wrong though
GEM module? Where is it? What is it? What's it look like?
I'm running into some wierdness as well, but not when it rains. My door switches are lighting up when the headlights are not turned on. Accessories don't work until I start the car and let it run about 13 seconds. Then I hear a "CLICK" from under the dash near the fuse block and wipers windosw etc work again. Just not the radio at all. What could make that click sound under the dash |
I just had something similar happen this week with the wiring coming from my radio though. I had pulled out my headunit to ground it and when shoving the box back in apparently I had kinded a wire or something because my speedo and odometer quit. Pulled out the unit and careful readjustment and its good now. |
looking4psd, To clarify, you said you pulled the headunit (Radio?) and there was a kinked wire that must have been the problem I did actually tie into the radio wires this summer to install a subwoofer. Do you think it could effect the power window switches? Had the door panel off, Saturday and couldn't fine a nick or anything in the wiring. Gives me something else to look at. Thanks
