Interior lights and "door open"warning staying on. - Ford Powerstroke Diesel Forum
99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only.
Old 09-23-2011, 03:56 PM
Just picked up my new-to-me 2002 Excursion Limited. I noticed the red "door open" warning on the dash staying on, and the interior lights stay on for quite a while when I get out and close her down. A mechanic buddy of mine says there is a "pin switch" inside the doors that is prone to fail on the Super Duties. Can anyone relate to this?
Old 09-23-2011, 04:04 PM
The Tamed Racing Driver
Yes my 99 does this when it gets in the mood. Hasn't been doing it lately
If the dinger isn't dinging all the time then its one of the other three doors.
The siwtch is in the latch, so you have to replace the entire latch once you locate the one thats your issue
Most (if not all) Fords use the same door latch so there somewhat easy to come across.
Old 09-24-2011, 04:43 AM
If you squirt wd-40 on all the door latches the metal things that spin around on the posts to hold the door shut it should work. Especially on the rear barn doors and hatch on the Excursions.
Old 09-24-2011, 07:57 AM
Feedback Score: 5 reviews
99% of the time this will fix your issue! Thank God for WD-40 and Duct-Tape!
Old 10-04-2011, 05:16 PM
mine was the back glass door. lubed the cables and works great now
Old 10-04-2011, 06:16 PM
Ended up being the driver door.... WD40 cured it!!! lol. Thanks, Boys : )
