| 99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only. |
Stupid questions to some
First Ford vehicle I have owned to drive on the road (except from field to field) in 20 years.
1.) Does a 2002 7.3 require the exhaust additive I see at Wal Mart? 2.) Does a 2002 7.3 need an upper cylinder lubricant ie. Lucas .-. atf? 3.) Does anyone use a Gulf Coast paper towel type bypass filter .-. the 1 .-. 2 ? 4.) If true to previous dumb question where did you mount it, access the pressure and dump the supply? 5.) How does changing and flushing the coolant help the mpg? ...---... I am sure to have more stupid questions ...---... :-) !!!!!!!! |
The only stupid question is the one not asked.
1. No exhaust fluid in a 7.3 2. Not required but I run 2 stroke ashless oil and/or diesel kleen upon fillups. 3. I have seen it but don't have one, I plan on getting the nuc motorsports bypass. 4. N/a 5. Coolant flush help mpg? New theory to me. Just make sure it has the right amount of additive with the test strips to avoid cavitation, or switch to ecl1 rated coolant |
No, however I do use a fuel additive since the 7.3 was developed prior to ultra low sulfur diesel. The sulfur acts as a lubricator for seals and such. I use Amsoil's Cetane boost and Diesel Additive Concentrate. No urea injection until the 6.7s came out if I am remembering correctly 2.) Does a 2002 7.3 need an upper cylinder lubricant ie. Lucas .-. atf? I've never used one, and caution any oil additives without doing your homework. If it causes the oil to foam it can lead to injector failure 3.) Does anyone use a Gulf Coast paper towel type bypass filter .-. the 1 .-. 2 ? I don't and don't know anyone personally who does. 4.) If true to previous dumb question where did you mount it, access the pressure and dump the supply?N/A 5.) How does changing and flushing the coolant help the mpg? I've never heard of this. Now, I could see if the engine ran at a cooler temperature it could raise MPGs, however, no coolant is going to lower the temperature that much. Each engine has its "optimum" operating temperature, and I know for a fact they aren't all exactly the same in the 7.3s. The 7.3 is a GREAT engine and doesn't need a lot of upkeep. Mine has 130K on it an it runs just as strong as it did when it was new. I know of many 7.3s that have had no mods, and no special care that have lasted an easy 400K. |
So you like it? I looked into buying the 203* and also the one offered by terminator (180* i believe)
Not sure why you'd go 180*. A lot lower than Ford OEM. I did the Dieselsite 203* Thermo and full billet thermo housing too.
But yes, I like it. It does run a bit better, mainly at full operating temp. As for MPGs, haven't been keeping track so idk but I wouldn't doubt if it helped a bit. |
