6" INCH LIFT AND DRIVESHAFT REPLACEMENT - Ford Powerstroke Diesel Forum
99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only.
Old 08-24-2011, 06:10 AM
I am installing a 6" lift in my Excursion shortly and was wondering about the driveshaft length and vibration.I read some people change them out for a driveshaft with a cv in it and others have no issues.For those of you that added lift did you change the shaft or leave it alone?Looking for some input.
Old 08-24-2011, 12:28 PM
Old 08-24-2011, 01:42 PM
Feedback Score: 5 reviews
Yep..contact Jess at Hi Angle drive line..thats who I used on mine.
Old 08-25-2011, 01:08 PM
Ive been wondering the same thing about the one piece drive shafts, I have a 6" lift on mine and have never bee able to get it as smooth as it was stock and I have the pmf adjustable bracket for the carrier bearing, don't get me wrong this is an extremely well built piece and I had great customer service, but I still havent gotten it dialed in perfectly. The drive shaft super store has a special right now forany lengh drive shaft up to 60" for only $245, seems like a good deal but arent ours longer then that?
Old 08-29-2011, 07:55 AM
Think they are.Some people have been fine with the angled blocks.i have also heard of some with the cardon joint in it and saw my first one today in a gas engine at work.Might research that a little.
Old 09-13-2011, 11:18 AM
Went with the 4" instead.It runs great rides great and didn't require any driveshaft work.Put the add-on block in with the 4" block I had and is perfect,
Even got rid of the vibration I had before.
