Short antenna? - Ford Powerstroke Diesel Forum
99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only.
Old 08-08-2011, 05:23 AM
Short antenna?
So we just brought home our new (to us) 01 4x4 ex..everything fits in the garage but the antenna hits the top of the door opening, it's really just an inconvenience but I am guessing the better half will be none to happy with it, so has anyone replaced their antenna with a shorter model that replaces factory?
Old 08-08-2011, 05:32 AM
I have the same problem with my truck. Be interested to see if anyone has a good suggestion.....
Old 08-08-2011, 05:36 AM
DBM DBM is offline
I made mine shorter, it is a common thing in the Mustang world. just pull the ball off the end, cut down the antenna, and grind the tip down till the ball will fit on it and super glue it back on... works great, I had to cut mine to park in my parking garage at work... I left mine just a couple of inches taller than my cab. kinda like a curb feeler for my roof
Old 08-08-2011, 05:52 AM
So that works even with the little wire twisted around it? Great idea btw
Old 08-08-2011, 06:42 AM
DBM DBM is offline
that isn't a wire, it is a ridge ground onto the antenna to reduce wind noise I think...
Old 08-08-2011, 07:14 AM
how bout that...thanks...
Old 08-08-2011, 07:27 AM
Okay, to jump in here....Does the ball at the end pull off, unscrew or ??? - I've read about it, but haven't done it, but definitely want to do it.
Old 08-08-2011, 08:05 AM
pull off, I used 2 pairs of pliers, I also soldiered the ball back on. little bit of paint and done..thanks for the tip.
