| 99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only. |
Anyone run water-meth kit on EX?
Wanting to buy a Snow Max MPG kit but don't want to mount the bottle in the cab. Anyone running a tank on the frame? How do you fill the bottle? I thought about having a custom tank made and mounting it under the passenger side frame and running a hose up to the access panel for the rear a/c to fill it up. Just looking for ideas and pictures if you have them.
Thanks |
sounds promising, do take pics and report, Is there not an option to use the wiper washer rez? or is it too small?
i travel too much to not have the bug remover juice. I remember seeing someone who had a frame mounted tank that was either 10 or 15 gallons and could be filled from a neck that ran into the rear storage door. I have a 30 gallon low profile metal tank that will fit, but I would have to have some type of filler neck fabricated and installed
My understanding is the pumps are gravity fed so the tank needs to be above them for it to work. You could always do a battery relocate and put a big tank there. Or depending on how much you are going to use it and or your wiper fluid they make parts to use your stock washer fluid bottle for them.
