| 99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only. |
wait to start light?
maybe someone could help me out real quick?
picked up an 02 ex recently and did not come with an owners manual. when i turn the key to on position theres no "wait to start" light. is there another light that i should be looking for? thanks |
Good chance your Fuel Bowl Heater element is bad, which will pop a fuse and shut your PCM off. (Same Fuse.)
Check your fuses, (#22 I think ) Unplug your Fuel Bowl Heater, and try and start it. If you do have a bad heater, make sure you buy the FORD one... I bought an aftermarket one and it crapped out immediately... it was TINY too, like 1/3 the size.
search a bit and read the 02 ex doesnt have a "wait to start".....it actually is the light to the left that has a few wavy lines?
It's a crappy video,, but here is mine on a cold start, the WTS light is the last on to shut off (at 19 seconds in the video). |
Heres a better video.... shows the WTS light flashing @ 31 seconds.
yup....looks like that "~" ....so thats actually the "wait to start" signal/light?
![]() When you turn the key to the "on-run" position, you should always wait for that light to go off before you start. While that light is on your glow plugs are heating up, and they draw a lot of juice, even when it's warm out. |
thanks a bunch!
