| 99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only. |
lift gain after Excursion spring swap
From what I have read, most people who install V code springs, gain around 1.5” of lift in the front.
My questions is, what is the amount of lift people have experienced in the rear after installing: unmodified B code springs? B code + one leaf? B code + two leaves? unmodified F code? F code + one leaf? For those who reply, please indicated what size block was used along with the spring installation. If RAS was also part of the set up, please note that as well. My desire is to install the V code springs on the front of my 2001 7.3l diesel Excursion, and do what is required to end up with the rear sitting 1.5”, or so , above the front. Thank you. Last edited by the ponz; 05-02-2011 at 10:59 PM. |
Anyone have input for this?
I am looking to go with the RAS system in the rear and heard that it will raise the truck 1 to 1 1/2" in the rear. It would be nice to hear this for sure. Looking to maybe go with a set of V code springs in the front and that should keep the truck level, maybe? What else is needed with the V code springs? Mike |
Beamer - Like I told you in the other thred, the RAS (both the old style and the new) raised my EX rear end 1 1/2 in. I have pictures if you want them.
D |
BTW - You should identify if you have a 4X4 and/or diesel engine. It does make a difference.
I did the front v code springs in my 2002, i gained about 1.5". The rear looks like it has a skid of cinder blocks in the back haha. I was going to order a set of b codes for the rear but can not find a set up cheap ones. So for time being im going to be installing a set of 4" lift block to replace the stock 2.5" Also adding a Hellwig rear sway bar. The front v codes made a world of difference.
We have helped countless Excursion owners over the last 7 years and have everything needed to mod the suspension. PM me and I'll get you all the info.
7.3 and 4X4 My truck currently sits 1 to 1 1/2" high in the rear. I think if I put a new set of V code springs in the front with a RAS in the rear with a Hellwig, I should sit about the same pitch as I am now, just a little higher. Then add a set of shocks and ball joints for the pop on the driver side that just started, darn it. And I will be good to go for a while. I currently have no sway bar on the rear and the truck feels not too bad unless I go over bumps etc and I feel the swishing like people describe. It just needs stabilization for the size it is. I have read about people putting the RAS and shocks at the same time and it sounds like I should put the shocks on first and then the RAS. With the RAS raising 1+", it gets difficult to bolt the shocks before cutting the compression band, hmmmm. Any words of wisdom? Thanks all for your input, Mike |
Cary (at CT) is a great source of information and parts. There are also many others on the Forum that have "Suspension" experience. I think it is probably the number one topic if you include "wander" as a suspension issue.
There are also as many differing opinions - and then some - (and objectives) in addressing the front and rear suspension as there are candidates for Presidential nomination!!! This is just my view and my experience so hopefully others will give alternative views. The rear sway bar had more positive effect on handling and towing than any other modification I did. I did it first so that may be "clouding" the results a bit. You must take the rear lower shock mounts off to mount the Hellwig ( and I suspect the Ford SD bar as well) since this is a pivot point for the sway bar. If you do shocks first then you should expect them to extend and need to be "re-compressed" when you install the sway bar second. When I installed V codes, I got the same lift (1 1/2in) in the front. The order that I approached it (again just my singular approach and not necessarily the optimum) was: 1) V codes 2) Front Shocks (same time as V codes) 3) Rear Sway Bar 4) Rear Shocks 5) RAS 6) Tighten Steering Box (carefully and search the forum about that) 7) 285 Michelin LTX 8) Ball joints (To Be done yet) 9) Red Head steering Box (when I find some unallocated funding My results have met all my objectives and the truck now sits about 1 1/2 to 2 in higher in the rear when empty, rides well, handles well when empty or towing, has lost most (if not all) of the wander) , and is absolutely a "perfect" tow vehicle for me. D |
X2 on the fact that CT Performance (Cary) was great in helping me get through my V/B mod upgrade on the 2000 Ex.
I went the expensive route and bought everything new - the only issue I had was with the swaybar mounts for the rear (got the wrong saddle clamps and bushings the first go round) got the right clamp (5") but they gave me the 3" bushings and brackets. Also - since I had used the stock sway bar I had to remove and cut the shock mount perch on the drivers side to mount the sway bar brackets - where I believe the Hellwig will utilize the stock shock mount bracket without having to do that and all told be a bit cheaper. Good luck! |
What size tire can you get under your Ex with just this lift ?
