| 99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only. |
AC quits when ESOF used
I thought I had read about this issue somewhere in the forum but can't find it now.
When I use the ESOF knob to shift from 2WD into 4WD , my AC suddenly quits and the defroster starts blowing like mad. In other words the vacuum solenoids that control all the duct work switch around. I know I have vacuum leaks on both hubs so I have been locking the hubs manually. After a short while, everyting returns to "NORMAL" but it sometimes "cycles" thru this series again as long as I am in 4WD. It's a real nusiance when it's 95+ outside and all we're trying to do is to get back to the TT on a rough back-country road. Anybody got some guidance for me? Thanks, D |
fix the vacuum leaks in your hubs. Problem solved
I thought that would do the trick or just "plugging" the hoses so there is no leak and using the hubs manually.
Thanks, D |
Your way= inexpensive and easy.
Dave's way= the right way to fix it. Take your pick which way is best for you. |
