HELP: Leak on top of motor! - Ford Powerstroke Diesel Forum
99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only.
Old 03-18-2011, 01:15 PM
HELP: Oil or fuel leaking from top of motor under fuel filter housing area! Anyone had this experience or know the procedure for repair? It's leaking all down the pass rear of the motor and caking my driveway!
Old 03-18-2011, 02:36 PM
check your fuel separator valve. its yellow,on back side of filter housing has two orings that leak.
search button will find you numerous threads on this.
Old 03-18-2011, 03:28 PM
if its oil its most likely Hpop, theres a couple threads on that as well
Old 03-18-2011, 07:13 PM
Ya, I just looked around the HPOP and it looks more wet around there than anywhere else. I'll order the o-rings and see where it gets me. Any other parts right there that should be replaced while in there?
Old 03-18-2011, 07:16 PM
Powerstroke Techie
The pump doesn't need to be removed to replace the o-rings. Just make sure that you have a torque wrench or you could strip out the threads in the pump and make really expensive junk really fast.
Old 03-18-2011, 07:21 PM
OK Thanks! Do you know of hand what the torque should be? I will try to look it up if you don't know. Any other preventive maintainance right there that can be done while I'm in there? New to diesel world!
Old 03-18-2011, 07:30 PM
Powerstroke Techie
25 lbs ft as stated in tsb 04-04-04.
Old 03-18-2011, 07:33 PM
Ah Man! You Rock! Thanks A Lot!!!
Old 03-18-2011, 07:34 PM
Powerstroke Techie
No prob .
Old 03-18-2011, 11:54 PM
Check out powerstrokehelp.com that guys videos are very informative, and has helped me on several occasion. Good luck on the o ring job.
