Fabtech lift question - Ford Powerstroke Diesel Forum
99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only.
post #1 of 7 Old 02-18-2011, 09:29 AM Thread Starter
Looking at the 3.5 Hanger lift by Fabtech, is the new sway bar a must have or will it work with stock bar. The reason I ask is, when I lifted my old Bronco (75 model) I bought the new sway bar as suggested with the kit and it was too long and would not even fit, so I didn't even use it. I don't want to spend that extra money if it's not needed, but don't mind if need be to make truck right. By the way this is on 01 Excursion
Thanks
secdawgs is offline
post #2 of 7 Old 02-18-2011, 09:37 AM
Raul@Stealth Automotive's Avatar
not sure on a excursion.. but i had the same lift on my superduty and i used the stock trac bar...
Raul@Stealth Automotive is offline
post #3 of 7 Old 02-18-2011, 12:01 PM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
Excursion are 2" lower from the incorrect springs Ford used..so you will end up 1.5" above where it should have been stock and need a adj track bar as the axle will shift about 3/4" from where it should be.
I wouldn't buy the kit I would fix the problems by doing what hundreds have done..replace the springs with V codes and modded B codes. If you want it taller then options are hanger kits, X codes etc..PM me if I can help.
Cary
CT Performance, Inc. is offline
The Following User Says Thank You to CT Performance, Inc. For This Useful Post:
dbryant61 (12-18-2014)
post #4 of 7 Old 02-18-2011, 12:45 PM Thread Starter
Cary, Thanks for your input, but for one I don't have a clue to what a V, B or X code is. My truck does not sit down in the front. This is not intended on being a leveling kit but to lift the whole truck.
secdawgs is offline
post #5 of 7 Old 02-18-2011, 01:18 PM
Quoted: 3 Post(s)
The stock Ex front springs are not rated for the weight and the rears are just a lousy riding spring.
What is done for starters is to get the spring that will carry the weight and ride correctly thats V code..std SD fronts and B codes Std rears.
We have you mod the rears..takes 15 min. This will raise the front 2-2.5" and the rear 1.5-2". front will be low 2"
For additional height front would be hangers from 2-4.5" rears usually just a taller block.
PM coming your way with lots more info.
Cary
proper shock slection, adding a 30mm rear sway
post #6 of 7 Old 02-18-2011, 02:22 PM
Don't want to hi-jack , but I am looking at lifts also . I recently purchased a 2001 Ex and it has a 4 in lift kit on it . They just used blocks and an add a spring is what I am told . I have owned and lifted many Jeeps , but this is my first full size . I don't like the cheap set up ( so I was told ) that is in it . I want to get a new kit that would come with all the springs and items to install .
The truck has 150k on it , so changing springs would probably be a good thing anyways . I have been thinking of the Icon 5 in , which comes with everything I am assuming , I don't want 5 in but it seems to be the best bang for the buck . Im not rich , but I don't believe in cutting corners , any help would be nice . Thanks
mikeg175 is offline
post #7 of 7 Old 02-18-2011, 02:34 PM
Quoted: 3 Post(s)
I'm a Icon dealer..that said its not what you want for a Excursion..PM sent.
Cary
