Remove Part of the Dash - Ford Powerstroke Diesel Forum
99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only.
post #1 of 11 Old 01-24-2011, 06:53 PM Thread Starter
Woody_PSD's Avatar
I need some help figuring out how to remove the part of the dash that has the outlet in it. It's the one with the garage door type opening located below the stereo. I just want to get that part out. Can anyone tell me how to do it? I don't want to break anything.
2001 Excursion Limited 7.3 PSD
4" Exhaust, Ford AIS Filter and Box
DP-Tuner F5 - Current Chip
Diablo Chip (not being used)
Superchips 1705 tuner (My code reader)
Broken Tranny as of 01/29/2011 --> New John Wood Trans shortly after. So far it's been awesome, spendy, but awesome.
Tire: Michelin LTX M/S2 LT275/70R18
**First PSD - Purchased 1/2/2008
My Site: mxguy.com
My Forum: allthingsmoto.com
Woody_PSD is offline
post #2 of 11 Old 01-25-2011, 12:19 AM Thread Starter
Woody_PSD's Avatar
Just an update with a picture. See attached. That is the panel that I am hoping to remove without taking the entire dash off.
My Site: mxguy.com
post #3 of 11 Old 01-25-2011, 12:44 AM
Fantom's Avatar
Quoted: 11 Post(s)
Feedback Score: 4 reviews
You just pull off that whole dash piece, it's held on by plastic clips. Only takes about a minute to take it off and unplug the 4wd switch, and adjustable pedal switches. Just pick a corner and start pulling, you won't break anything.
John
2004 Harley Davidson F250 #1191 - 6.0 Powerstroke
Studded - Lots Of Bulletproof Diesel Parts
Swamps 58v FICM - KC Stage 2 Turbo
Ported Intake - S&B CAI
100,000 Miles
Live in Northern California? Stop in here and say hi
Fantom is offline
post #4 of 11 Old 01-25-2011, 01:29 AM Thread Starter
Woody_PSD's Avatar
I'm guessing just use a screw driver in there and start prying then... Sounds easy enough.
Thank you. I really didn't want to break it and I wasn't sure if it would come out or not.
My Site: mxguy.com
post #5 of 11 Old 01-25-2011, 01:35 AM Thread Starter
Woody_PSD's Avatar
Actually are you talking about the entire dash panel or just that square section with the power plug?
My Site: mxguy.com
post #6 of 11 Old 01-25-2011, 01:48 AM
Fantom's Avatar
Quoted: 11 Post(s)
I'm talking about the whole dash section, the part where the plug is, isn't a seperate piece, it's all one piece. I wouldn't use a screwdriver, because you may crack the plastic. Start at a bottom corner where you can get a finger grip on it and start pulling
John
100,000 Miles
Fantom is offline
post #7 of 11 Old 01-25-2011, 01:58 AM Thread Starter
Woody_PSD's Avatar
Ahh okay. New screws or anything? I don't need to remove the stereo do I?
Thanks for your help. As you can see I'm a bit nervous about breaking something...
My Site: mxguy.com
post #8 of 11 Old 01-25-2011, 02:02 AM
Fantom's Avatar
Quoted: 11 Post(s)
There are no screws, if you have the stock radio, then yes, you will need to remove it. Ford has special tools that you can make from a wire hanger. There are 4 holes in the face of the radio, cut a piece of hanger about 10-12'' long for each side, make a loop and stick each "prong" in the holes, push forward as far as it will go easily, push the loops outward while holding them, slide the radio out.
Here's what the tools look like, if you haven't seen them before
John
100,000 Miles
Fantom is offline
post #9 of 11 Old 01-25-2011, 02:06 AM Thread Starter
Woody_PSD's Avatar
Awesome. Thank you for all your help. I will get it done tomorrow.
My Site: mxguy.com
post #10 of 11 Old 01-26-2011, 10:04 AM
TXSailor's Avatar
My dash had two screws in the radio opening ( at the top) that kept the Dash plast ic piece in place. I needed to remove them before the dash would come out.
D
__________________________________________________ ____________________
2011 F350 King Ranch CCLB 4WD, 6.7L,Bilstein Shocks, Hellwig Sway Bar.
TXSailor is offline
