Pulling,wondering ,and steering vibration - Ford Powerstroke Diesel Forum
99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only.
Old 01-05-2011, 07:17 AM
OK >> Here goes..
Just purchased a 2002 Excursion, and at first it pulled hard to the left while braking(the dealer did a front brake job before I bought it).That has since cured it's self, but I'm left with a pretty hard, and steady pull to the left. I also have a wobble in the steering wheel at various speeds that is more prevalent at speeds above 75 m.p.h. I had the wheels rotated and balanced, as well as an alignment... everything checked out..in fact the alignment guy said it was dead on didn't adjust anything, and said I should be going down the street straight. The last thing is the ever so special moment when the truck isn't pulling left it has a wonder to it.. were I feel like I have to constantly be steering the truck to keep it going straight. Any help would be appreciated.
Old 01-07-2011, 10:24 PM
Sorry, you bought a Democrat's truck! Maybe get an Abe Lincoln or Ronald Reagan bumper sticker and it will stop pullin' to the left!
Old 01-08-2011, 07:35 AM
LMAO....
Or maybe slap an Obama sticker on it promising prosperity, hope, and change..just to deliver poverty, dis-pare, and hoplessness... all with a great smile of course.
Old 02-01-2011, 09:41 AM
Jack up your front end and spin your wheels by hand to check for a dragging brake caliper on the left side. That's all that I can think of that could cause a pull left providing the alignment guy knows what he's doing. As far as the wonder and wobble, could be many things: Worn ball joints, tie rod ends, track bar joints, steering box gear mesh (which can be tightened). Start with checking these and also remove steering stabilizer and inspect for replacement.
