What does everyone run for batteries? - Ford Powerstroke Diesel Forum
99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only.
post #1 of 32 Old 11-29-2010, 09:27 AM Thread Starter
I was just wondering what everyone runs for batteries in there trucks/Ex's. I have Oddessey's in both my suv's. They are a dry cell AGM battery with 930cca. They seem to do the job.
It's not what you buy, It's what you build
07 F350
6.0L Diesel
Muddyrc is offline
post #2 of 32 Old 11-29-2010, 04:54 PM
JSchuricht's Avatar
In my 00 I run the Diehard Platinum batteries which are re-branded Odyssey's and much less expensive. I also have a 2400 Kinetik which will auto jumpstart the primaries if needed.
In my 95 I have some cheep Costco batteries that somehow recovered after the truck sat for 1.5 years. The batteries registered less than 1v when I got the truck. How they manage to start the truck when it's 25* outside still baffles me.
JSchuricht is offline
post #3 of 32 Old 11-30-2010, 09:03 AM Thread Starter
That's crazy. They are the same battery at half the price.lol Do you like them? How long have you had them?
DieHard | DieHard Battery Selector
07 F350
6.0L Diesel
Muddyrc is offline
post #4 of 32 Old 11-30-2010, 09:24 AM
cowpuncher's Avatar
I perfer to run Interstates have a great warranty and one of my local dealers on them always makes me a deal when I need new.
Its the long skinny pedal on the right Cupcake
cowpuncher is offline
post #5 of 32 Old 11-30-2010, 07:22 PM
JSchuricht's Avatar
I have had them for about a year. No complaints yet, but I am bias toward SLA batteries.
post #6 of 32 Old 11-30-2010, 10:10 PM
BraveHeartCalif's Avatar
im very happy with the Interstate
2003 4x4 7.3 Excursion
JW Valve Body
Parker/Racor Bypass Filter 3-micron
Parker Marine Outboard Fuel Filter Water Separator
V Code & B Code Leaf Spring upgrade
Dual Bilstein Custom valved Front Shocks - Rear singles
4" ICON Front Shackle w/ Rear Blocks
ICON Front Pan Handle Bar
PHP CHIP-80 DD, 120 Racer, 120 Smoke, Whisper, 1200 High Idle
CCV Mod
Tymar Intake
Wicked Wheel
A self modified Riff Raff FRX w/ 900 PSI inner titanumum hose and SS outer braid. Temp rated 500 degree
BraveHeartCalif is offline
post #7 of 32 Old 12-01-2010, 06:38 AM Thread Starter
Why are you bias towards SLA? That is good technology. Optima's and Oddessy's are able to handle a high rate of charge unlike Gel's. They are good in many different applications. I also use AGM's at home for my backup power unit.
How do you have the Kinetik wired in. That is also a AGM battery isn't it?
07 F350
6.0L Diesel
Muddyrc is offline
post #8 of 32 Old 12-01-2010, 10:52 AM
shfletchak's Avatar
Optima Red tops...they have more cranking amps than most average batts
2005 F250 CC FX4 6.0L SCT Livewire, 4" Turbo back MBRP Exhaust, EGR/DPF Deleted, Zoodad, Airaid Intake, 33" BFG ATs, Leer Browning Edition Topper, High Idle, High beam-fog light Mod, Airlift Springs, homemade lightbar/4 Moose lights
2004 F150 SCrew 4X4 4.6L
K&N Intake, Flowmaster Dual Exhaust, 33" BFG ATs, leveled, Smittybilt Brush gaurd/tube steps, 4 Moose lights, Air helper springs, Leer Browning Edition Topper
2011 26Z2 Arctic Fox TT
shfletchak is offline
post #9 of 32 Old 12-01-2010, 07:33 PM
JSchuricht's Avatar
Wasn't really thinking when I said that, AGM are valve regulated. Should have just said I don't like dealing flooded batteries. Too much work and too much mess.
The Kinetik is setup to power my amps and air compressor. It is connected with 4/0 through a 500a relay and a battery isolator controller. The controller connects the aux battery for charging when the voltage hits ~13.5 or if the starter is engaged with the main batteries at a low voltage.
post #10 of 32 Old 12-02-2010, 12:12 PM
HOUTX01X's Avatar
Quoted: 4 Post(s)
interstate megatrons
'11 F250 KR
XRT Pro, H&S SX-E turbo kit, NoLimit intake/intercooler
OUO bars/blocks
-EGR,CCV,1993pf
Leveled w/ 35 atII
HOUTX01X is offline
