| 99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only. |
Replaced Fuel pump now have slight miss
Had the fuel pump on the frame rail go out. replaced it and now have a small miss up to 60mph. It is very slight but noticeable especially when climbing a hill. I replaced it with one from Autozone as I was stranded on the side of the road on a Sunday. Did a contribition/buzz test and everything passed plus no codes are present. I am stumped as to where to start looking. Should I get a pump from ford for $421? Could it be pressure thing with the pump from Autozone?
I wouldnt use an autozone fuel pump. Get a Ford stock fuel pump or one of the better after market units. Who knows if the autozone unit is outputting the right psi.
that is what I first thought as it might not meet the required psi. I will swap it out and see what happens. I just hope that while the fuel pump was on its way out that it did not take an injector or two with it. But a buzz test would have shown that correct? The other thing I have noticed is that my mpg's is dropping just a bit and driving habits are not.
check your fuel pressure before throwing money at it
whers is the best place to check to make sure I am getting the best reading?
needs a mechanical fuel pressure gauge or if you have the sensor for it, that will work
7.3s dont read pressure results to the pcm. i had fun tellin autozone that a new "fail safe" tstat stuck open when i returned it. one of their best ones on the shelf in the back. |
I always pay more and put in oem equip on my 7.3 because i cant afford to get stuck where i go. The only time so far i have not gone ford oem, was when i bought a Napa Auto's "top of the line" new (not rebuilt)alternator. Its been working great and been a solid performer for almost a year.
I try to buy oem if its not drastically different in price.
Except for the factory glow plug relay
Stancor or Western is the way to go.
What should the pressure be?
