| 99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only. |
excursion front springs
does anybody know what the gap between the axle and the bumper stop on the frame should be
2+" but since the stock Ex. springs are not rated for a diesel your Lucky to have a 1/2" You need to install V codes..many things can be done to correct the handling problems of the excursion. PM me if I can help.
Cary |
thanks i needed a place to start put new bumper stops on a little tight. but 2 inches i have. if i put a 1.5 to 2inch lift. is it just the springs or a bunch of other parts?
You have a diesel? Whats the door sticker spring code..you shouldn't have 2" stock..
2" additional 2 ways a hanger kit or a mini spring pack. Hanger kit needs longer shocks Mini spring pack doesn't Both require a adj track bar. Let me know.. Cary |
door code; under SPR: are the letters DG, it's a 2002 limited 7.3 64k miles 3.73 limited slip. manufactured 1/02. remeasured everything. front bumperstops to axle 1/4 inch,front wheels to wheel well 7 in. ground to wheel well 37in, rear bumper stops to axle 2 3/4in; wheel to wheel well 8 3/4; ground to wheel well 39in. I don't offroad just tow a 30ft tt. and get around in the snow.
You need to mod it. If you want your Ex to handle and ride better and be safer than you can imagine PM me.
Cary |
