Guys with 35'' tires???? - Ford Powerstroke Diesel Forum
99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only.
Old 08-22-2010, 10:52 AM
What size lift are you running to accomendate the tires? Thanks Ross
Old 08-22-2010, 11:03 AM
<<---"Shadow"---
I ran them on stock rims with just a leveling kit.Now i run them on stock rims with a 4 inch lift. Had rubbing issues before the 4" lift. None now.
Old 08-22-2010, 11:09 AM
same here.
Old 08-22-2010, 11:18 AM
Feedback Score: 7 reviews
Send a message via AIM to dereku
Nice lightning in you avatar.
Old 08-22-2010, 11:22 AM
4" lift. The only rubbing I had was the plastic on the very bottom of the bumper, I just trimmed a little of that and its all good now.
Old 08-22-2010, 11:24 AM
Thanks dereku.
I have a 3'' lift all the way around so I should be good
Old 08-22-2010, 03:24 PM
SEA71 I had a truck that looks just like yours and traded it for a POS 04 crew 6.0. Man i'm kicking myself for trading it in
Old 08-23-2010, 12:01 PM
Feedback Score: 5 reviews
The best solution to using 35" on a Ex is V and my B code mod with 3" front hangers and 3.5" rear block. I've helped hundreds solve the handling problems of the Excursion. Many posts on all the forums about the results.
PM me if I can help.
Cary
Old 08-23-2010, 05:20 PM
4" but I did mine a little hodge podge. x-code fronts springs with 2.5" BDS shackle kit. Rear springs are 4" skyjacker soft rides. Billstein shocks
Old 08-24-2010, 11:31 AM
I had 2.5 leveling kit and had the tires rub at full lock on the steering wheel.Not a big deal to me except parking gets a little tight.Now running 37/12.50/20 and swapping a 4"
block tonight.
