Cab Lights on Ex - Ford Powerstroke Diesel Forum
99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only.
Old 07-15-2010, 05:03 PM
Cab Lights on Ex
Ok I am doing my cablights on sunday but I am NOT going to buy the harness as it is 90 bucks since i got the overhead console I was wondering which wire behind the headlights to tap into? any one know 01 excursion BTW
Old 07-15-2010, 05:11 PM
Get a test light or meter and you can test that way...you are just going to run the wire down the pillar to the switch right?
Old 07-15-2010, 05:16 PM
yes both dealers here wanted 90 bucks for the harness since mine has the compass thing and i said screw that just going to tap in to the switch just as easy and saves me a hundred bucks
Old 07-15-2010, 05:20 PM
Have you checked out Gorecon.com ? they have the harness lights and all for $90...unless you already have everything you need
Old 07-15-2010, 05:30 PM
I got my lights and it comes with the harness to hook up each light all i gotta do is run it to the switch and install them
Old 07-15-2010, 05:38 PM
Good deal...I have a good write up bookmarked if you want it...although it is for F-series so it will be slightly different...not too bad though
Old 07-15-2010, 05:42 PM
Prob same ones that I have got but throw them on the board I am going to do a very detailed write up if time allows
Old 07-15-2010, 05:53 PM
Cab Lights + Install/Pictures/DIY
Motoman's Madness
Old 07-15-2010, 08:27 PM
I did a small write up but no pics, it's easy to install but run the wire down the driver side pillar then tap into the harness on the headlight switch, for the parking lights, I tested every damn wire on the overhead and the passenger kick panel.
Old 07-16-2010, 03:43 AM
And what wire would that be
