PSD oil pan needed....... - Ford Powerstroke Diesel Forum
99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only.
Old 05-16-2007, 05:43 PM
The first oil change on my (new to me) 2000 Excursion PSD went fine, except I noticed a lot of salt cancer on the oil pan from previous Ohio winters.
I'd rather fix this on my own terms than spill 14 quarts on a deserted hiway some day.
Anybody have a line on a junked 7.3 that still has an intact oil pan? Anybody know of an oil pan that's still roadworthy? Thanks!
Rick
Old 05-16-2007, 06:07 PM
I have a 4R100 trans pan, but no used engine pan. I will keep my eyes open though.
Old 05-16-2007, 06:46 PM
Feedback Score: 7 reviews
Send a message via AIM to dereku
I just bought my from advanced auto parts or one of those common parts stores cant remember witch one though but it seemed like an ok deal at the time was about 2 years ago wasnt too expensive
Old 05-16-2007, 06:55 PM
u might as well go and buy a new one. that way u know that it is in good shape. however it might be a good idea to buy the junk 7.3 for parts. extra hpop for possible future upgrades. just remeber that u gotta take the engine out
Old 05-16-2007, 09:27 PM
Paint it
I'm in the same boat with rust on the oil pan.
After some 'research', I think the best idea is to clean the pan well, and as long as there is no holes or the rust isn't too deep to use the 3 chemical system from POR 15 and put a topcoat of chassis black on top.
This is what I'm planning on doing.
Just wish I would have known about this and done it when it was new.
So for all you guys out there with NEW trucks, take heed and do it now!
Old 05-17-2007, 03:07 AM
I know I could look,
but will the engine need pulling to R&R the old pan? If so, what the the usual suspects to replace while I'm there? Engine mounts, etc? The X has 100K miles on it.
Old 05-17-2007, 03:35 AM
Almostdunfukinwidit
I just wire brushed and painted mine
Old 05-17-2007, 05:13 AM
You will atleast have to lift the engine. I would do the rear main seal while your in there.
Old 05-30-2007, 12:14 PM
You can't just lift the motor your you will have oil leaks, you have to turn it over and clean it good... If your pans not bad, just coat it and be done, very costly and PIA to swap a pan out!
Old 05-30-2007, 12:22 PM
...turn the motor over to do it right? I don't think so!! ;-) While the cancer looks bad, looks like I'll hit it with naval jelly and coat with primer then undercoating.
Thanks for the warning, CSIPSD
