power window problems - Ford Powerstroke Diesel Forum
99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only.
post #1 of 22 Old 05-24-2010, 10:26 AM Thread Starter
excursionMark's Avatar
Send a message via Skype™ to excursionMark
ok so my windows dont work ... i checked all of the fuses and they are all good ... the 5 amp on the fuse panel inside the truck and the 30 amp cb on the fuse panel under the hood ... they were working then they stopped so i pulled out the 5amp fuse and put it back in with the door open and it worked but stopped working the second i closed the door and when i repeated the same thing with the door closed it didnt work at all but with the door open it worked a few times then finally stopped working yesterday now i cant move my windows at all ... and the rear glass works (the ones that go outward not down) ... ne help/ suggestions would be greatly appreciated
2000 Ford Excursion
7.3L Powerstroke Diesel~DP Tuner (Stock.Drive Thru.High Idle 1400.80 Economy.120 Race)~05 front end~DIY AFE Pro Dry S Intake~Viper Alarm/Remote Start~55w 8000k HID~Whelen Strobes~Pioneer AVH4100~Alpine Type X Component Speakers~2x12” Type X Subwoofers~Alpine PDX 1.1000 Amplifier~Custom Center Console
excursionMark is offline
post #2 of 22 Old 05-24-2010, 11:47 AM Thread Starter
bump. ttt.
2000 Ford Excursion
post #3 of 22 Old 05-24-2010, 11:53 AM
SuperCrutyPS's Avatar
Quoted: 343 Post(s)
Garage
Have you checked the wiring running in/out of the door through the jamb? Do you get door open indication?
I'm just throwing it out because my daughter's Jeep Grand Cherokee did something similar. No window control from the driver's door, the dome light stayed on. Turned out to be a broken wire in the loom running to/from the door.
Like I said, just a suggestion.
Owner | Operator: Darryl
My Truck Garage:
Tow Toy Garage :
United States Navy - IC2 - '76-'80
SuperCrutyPS is offline
post #4 of 22 Old 05-24-2010, 11:54 AM
symbols's Avatar
sounds like it's a wiring problem in your door where the wires bend back and forth from opening and closing the door I assume this is the drivers door your opening and shutting?
Jason
"Using a thug's murderous rampage to call for gun control is like using Barack's reckless spending to call for higher taxes."
--Michael Berry, American philosophizer & Talk Radio Czar, 1970-?
symbols is offline
post #5 of 22 Old 05-24-2010, 11:56 AM Thread Starter
yeah im probably going to end up ripping the door panel off and seeing whats going on but the thing that puzzles me most is that none of the other door controls work like the passenger control cant roll down the pas window or anything
2000 Ford Excursion
post #6 of 22 Old 05-24-2010, 11:57 AM
symbols's Avatar
That's because it all runs through the drivers door
Jason
symbols is offline
post #7 of 22 Old 05-24-2010, 11:57 AM Thread Starter
yeah its the drivers door ... and i was planning on looking in that loom before i took the whole door off ... im pretty lazy haha
2000 Ford Excursion
post #8 of 22 Old 05-24-2010, 11:58 AM Thread Starter
really?? **** im dumb ... well then im pulling the drivers door off now haha ... deff didnt know that ... thanks for that insight .... i feel real dumb now
2000 Ford Excursion
post #9 of 22 Old 05-24-2010, 12:01 PM
symbols's Avatar
Yep. IIRC if you unplug the drivers door window switch none of the other windows will work
Jason
symbols is offline
post #10 of 22 Old 05-24-2010, 12:05 PM Thread Starter
aha ... that would explain this problem haha ... now i just have to figure out how to get the door panel off ... its been a while since i last did it
2000 Ford Excursion
