Play in steering help - Ford Powerstroke Diesel Forum
99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only.
post #1 of 7 Old 04-21-2010, 12:57 PM Thread Starter
I have a 2001 7.3 ltr 4x4 excursion with a 4 inch lift and 33" tires on it. 84k mi. I have about 3" of play in the steering. Before I order a steering box, is there anything else I should check first?
dieselexcursionfor6 is offline
post #2 of 7 Old 04-21-2010, 12:59 PM
purplehorn1977's Avatar
tie rod ends and drag link ends
2004 F250 6.0 CC 4x4 SCT with custom tunes
zoodad mod, head studs, Home Brew EGR delete, 5" MBRP striaght exhaust, 05 headlight Conversion
HID Head and fogs.
Real courage is found, not in the willingness to risk death, but in the willingness to stand, alone if necessary, against the ignorant and disapproving herd. Jon Roland, 1976
purplehorn1977 is offline
post #3 of 7 Old 04-21-2010, 01:07 PM Thread Starter
Thanks. I'll do it
post #4 of 7 Old 04-21-2010, 01:14 PM
aawlberninF350's Avatar
If the ends and links are good, the steering box has some adjustability to account for internal wear. Open the hood and look down at it. On the top front you will see an allen headed bolt with a jam nut. Back off the jam nut a turn then tighten the allen bolt a bit, maybe 1/2 to a full turn, then tighten the jam nut again. Be sure to hold the adjustment on the allen bolt while tightening the jam nut. There is a spec for preload on the gear but every one I've seen has so much friction in tightening the allen bolt that the preload is moot. Take it in small bites, drive it, repeat, until the play is pretty much gone. Over torqueing the preload will wear out your steering box quickly.
02 F350 Lariat 4X4 CCSB SRW 4R100 w/FTVB.Mishimoto 6.0 IC.26 row 6.0 trans cooler.6637.WW.RiffRaff FrxGen2/Plenum inserts/AIH delete/boots.Hutch.Harpoon.50 cent.Isspro EVs.Walker BTM.DP Tuner.AC mod.Mile Marker 449ss.Fumoto.DDM HID 55w 4500k.Bilsteins.Dieselsite Coolant Filter.
Every normal man must be tempted, at times, to spit upon his hands, hoist the black flag, and begin slitting throats. - HL Mencken
aawlberninF350 is offline
post #5 of 7 Old 04-21-2010, 01:18 PM Thread Starter
Awesome. Thanks
post #6 of 7 Old 06-01-2010, 05:34 PM
scagle1's Avatar
Run into 3 different superdutys where the nut holding the pitman arm to the pump has backed off causing slack in the wheel.
Sold 01 350 6" on 37's and mild mods, 00 X 4" on 35's, 02 f350 4" 35's modded from fan to drive shaft, ridin the 03 with nose conversion with 125k and counting upwards slowly.
Never had CNC's poo on any of it, never will.
scagle1 is offline
post #7 of 7 Old 06-02-2010, 07:36 PM
gmaredd's Avatar
Good call - happened to me.
1997 F250 XLT 7.3 ENGINE
Extra Cab Longbed
285/75/16 BFG Tires
Standard Transmission
Heavy Duty Clutch
ATS Turbo, Intercooler
4" Straight Exhaust
K&N Air Filter
Superchips Programmer on Tow safe
Pillar Gauge Pod with AutoMeter Boost, Exhaust Temp
gmaredd is offline
