Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 Ford Excursion Forum
99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only.
Old 04-25-2007, 05:30 PM
4xtaco 4xtaco is offline
'00 Ex/ Prodigy Wiring
This is in an '00 Ford Excursion... We just purchased this vehicle and I am trying to put our Prodigy in and I know there is supposed to be a pigtail, except when I got under the dash this is what I found- Is there supposed to be a factory pigtail attached to this? It isn't a huge deal except I purchased a Prodigy pigtail with the intention on using it.
The wires match typical trailer wiring- Red, Blue, Black, White and White w/ Bl strip
Old 04-25-2007, 05:35 PM
bigcountrysg bigcountrysg is offline
duct tape & zip ties
Yes there is supposed to be a connector on that wiring. Looks like somebody cut it off. Just match the wires up and connect them.
Old 04-25-2007, 05:36 PM
SCUFFY828 SCUFFY828 is offline
FORD TECH AND ADMIN ....
yep probably had one on it and someone decided they wanted to keep it
Old 04-25-2007, 05:41 PM
Yes... and it was a prodigy according to the sticker on the dash LOL. Oh well I guess I have a pigtail to sell now. Back to wiring... Thanks everyone. I'll solder everything nice and neat though.
Old 05-24-2007, 11:34 PM
Blue01F250 Blue01F250 is offline
Tournaments Won: 1
Did it work when you soldered the wires?? I also have a prodigy and it plugs into that gray connector in the upper right of the picture.... not where those wires are cut.....
Old 05-25-2007, 08:30 AM
bamaboy473 bamaboy473 is offline
for the technically-challenged...
what exactly IS a Prodigy and what does it do for us?
Old 05-25-2007, 08:46 AM
honeyc_j honeyc_j is offline
The gray connector in the corner is where you connect the prodigy to, you would have to buy the wiring harness from ford or an aftermarket vendor and connect that to your prodigy controller wiring harness. The wiring harness pigtail from ford should be about 13 bucks or so.............:whistle:
Old 05-25-2007, 03:26 PM
Tournaments Won: 1
It is a brake controller made by Tekonsha - it controlls your trailer's brakes if it is so equipped.
Thats what I was saying - I plugged mine in with the harness that has connectors on both ends, not one you have to wire up and it went in the gray connector in the upper right - thats why I asked the question I did of the original poster b/c they were going to wire their controller to the cut wires they were pointing to.....
the plug'n'play harnesses are great!!!
Old 05-26-2007, 06:33 AM
Thanks, Blue
I have one of those Tekonsha units, just never knew it went by the name Prodigy.
Old 05-26-2007, 10:16 AM
Tournaments Won: 1
no prob bamaboy - Teknosha sells several controllers -- the Prodigy looks like this
