Dynatrac Freespin kit - Ford Powerstroke Diesel Forum
99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only.
post #1 of 10 Old 03-22-2010, 06:01 PM Thread Starter
excursionMark's Avatar
Send a message via Skype™ to excursionMark
Will a Dynatrac Freespin kit go on the excursion ... it says so on a site that sells them but i didnt see anything specific on the dynatrac website ... thinking about investing in it and just want to make sure the website in correct in saying that they fit on an excursion
2000 Ford Excursion
7.3L Powerstroke Diesel~DP Tuner (Stock.Drive Thru.High Idle 1400.80 Economy.120 Race)~05 front end~DIY AFE Pro Dry S Intake~Viper Alarm/Remote Start~55w 8000k HID~Whelen Strobes~Pioneer AVH4100~Alpine Type X Component Speakers~2x12 Type X Subwoofers~Alpine PDX 1.1000 Amplifier~Custom Center Console
excursionMark is offline
post #2 of 10 Old 03-22-2010, 07:06 PM
Hemicross's Avatar
I really don't see the need since you have the option to unlock the hubs with the factory 4wd, but if you really want to spend 2 grand on the kit I don't see why the ones for the f-250 wouldn't work, same axles and steering knucles along with hub assembly, it should interchange
2000 Limited 7.3 PSD 4x4 Excursion, 210,000 miles, S&B cold air, 4" TBE straight pipe, add a leafs, pro comp shocks, hellwig rear sway bar, recon smoked led cab lights, limo tint, 1-piece headlights, 8000k hid's, PHP phoenix chip, Firestone ride rite airbags
Hemicross is offline
post #3 of 10 Old 03-22-2010, 08:52 PM Thread Starter
its the same axle? i could have sworn the ex has a dana 50 and the f250 and 350 have dana 60 front axles .. i could be mistaken tho .. but my bearings r going bad im prett sure and figured why not might as well upgrade .. not 100% sure if im going to do it or not yet tho lol
2000 Ford Excursion
post #4 of 10 Old 03-22-2010, 09:00 PM
choupique108's Avatar
caryt would be the one to ask on this. He has done alot with the X
1997 Single Cab Dually, S366 w/ Irate mount and plenums, EFuel, Intercooler, P.I.S 175/80s, Corbeau seats w 08 console, 19.5s, 6637, Black Interior with swede headliner and visors, Custom badges, Flight Fab Traction Bars.
choupique108 is offline
post #5 of 10 Old 03-22-2010, 09:02 PM Thread Starter
valid point .. well if he doesnt see this by wed ill email him about it ... dont wanna bother the guy if i dont have to
2000 Ford Excursion
post #6 of 10 Old 03-22-2010, 11:38 PM
Hemicross's Avatar
Yea that's a good idea, I would figure they would be the same but don't take my word for it, I'm new to ford diesels
post #7 of 10 Old 03-30-2010, 12:37 PM
I just got done installing the Dynatrac free spin kit on my 01 Excursion. Yes it does fit, I would make sure you get new u-joints. They will send spacers for the brake calipers when you re-install them. Mine took the .300 spacers, which is the larger of the two. Couldn't be happier. For the vacuum hose for the 4 wheel drive system that goes into the knuckle, take the threaded end off the hose insert a bearing and reinstall the threaded end, that will plug the vacuum hose and you can reinstall it on the knuckle. Good luck.
StHubert is offline
post #8 of 10 Old 03-30-2010, 09:16 PM Thread Starter
thanks for the info man im still debating the idea of the freespin kid ... idk if i can get that much cash together at the moment but good to know it fits thanks for the info
2000 Ford Excursion
post #9 of 10 Old 03-31-2010, 06:22 AM
No problem. If you do it, have extra cash for extras. Ball bearings, shocks, u-joints, brake pads, rotors. Once you get in there you might as well replace anything that might need replacing.
StHubert is offline
post #10 of 10 Old 08-18-2010, 07:31 PM
heykw's Avatar
their is another company that make the kit at about 65-70% the cost. The name slips my mind now.
Excursion 02 4x4 Silverline exaust superchip tuner
Excursion 2000 4x4 300K miles 238/100 P.I.S. Injectors 38RW/ billet wheel dyno proven tunes
99 F350 7.3 4x4 body build date 02/98 motor build date 12/97 19.5 ricksons (Sold)
heykw is offline
