| 99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only. |
03 excursion 05 parts
I have a 2003 Excursion and i would like to know if the 2005 Excursion grille and head lights will fit on my truck without a lot of work? Thanks in advance
Headlights yes, grill no.
the 05-07 grill's are taller then pre 05, you can cut it but i think it will look like booty. to do this without cutting you will need to purchase these 05-07 parts... -lower bumper - metal -upper part of bumper - plastic -bumper brackets - 4 -grill -headlights - will need to get the 05-07 bulb connector from ford or wrecked veh. "your stock 03 wiring will not connect to 05 bulb and 03 bulb will not fit in 05 headlamp. -grill and headlight support - this is behind grill / headlights it has the mounting holes for these. Hope this helps, mine is a 2002 below you can see my setup. Rob |
Hey I got a diesel magazine with someone doing an 08 front end on a 99 f250, anyone know what all parts are required?
guy local to me in michigan did that swap already
ill find pics |
