| 99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only. |
does anyone have or know where to get a parts diagram or blow up of lock assembly of 01 ex rear glass,,,wont lock with or without key
thanks: |
same problem here, key wont even fit in the lock. so i fixed the lock actuator so it locks now at least
Most likely fouled up from using the key fob.That is most often the problem we see @the dealership here.
I have a parts diagram here that I can try to email or can fax.Funny reading this I think I
need to try my key later on the way home. |
rear glass 01x
pm sent thanks............
I'll send it tomorrow from work.I split right at close and didn't check my computer.
I'm having the same issue guys, could I get that diagram too please??
similar issue- i went in to fix the actuator but it works fine. The issue is the latch doesn't pull the cables far enough to release the jaws/clamps on the edges (the part that actually holds the liftgate closed). Any ideas how to fix/adjust those? I sprayed with lube and hope they will work better?
