| 99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only. |
Just a ? on exhaust
Been looking around at exhaust for my truck and noticed no one makes a 5 inch for an excursion. Does anyone know why, is it the fuel tanks on em or what? Thanks
I just put the 4inch mbrp on my 02 excursion and it was real tight by the rear shock area and the trans crossmember.I honestly don't think the 5 would go
but I could be mistaken. |
I thought I saw a set up from Flo Pro, its been awhile since I looked.
On a side note 5 inch is over kill unless you want big power, only reason I got it was cause I saved for the 4 inch MBRP then found Flo Pro not knowing I should have saved my $$. |
So did you notice any improvement with the larger exhaust on your Excursion?
Thanks Mike in GA btw my Excursion is stock and that woudl be the only change, I'm really happy with the stock performance so far so I hesitant to mess with it too much |
Go to rollinsmokediesel.com they have 4" to 5" exhaust, biggest u can go off turbo is 4" to get it down under the truck, then it goes to 5"
