windshield washer fluid leak - Ford Powerstroke Diesel Forum
99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only.
Old 01-26-2010, 04:51 PM
I hit the washer fluid for the back window just a bit ago and it started to drain out of the molding that meets the back window inside the truck. I popped a couple panels and found nothing busted. My ceiling liner was a bit wet right on the edge but i dont know if that was because the leak was back that far or it just ran to the liner.
anyone ever seen this and know where the leak hopefully is? If it is back over the liner like i fear, i may be screwed, that looks like a B****....
Old 01-26-2010, 06:14 PM
Send a message via Skype™ to excursionMark
i have the same problem ... i havent ripped it apart yet so idk what the prob is but heres a bump
Old 01-27-2010, 05:48 PM
When I hit mine it sounds like it's leaking somewhere around the right lower fender...
Old 01-27-2010, 08:17 PM
I have the exact problem, as well. Haven't had the time to look into it other than removing the moulding, as you did. Hope someone has a fix. I sometimes forget and I hit the fluid button, then CRAP, just soaked the liner!
Old 02-01-2010, 05:27 PM
same thing with my 05, who ever finds the problem and fix please post it... thanks
Old 02-03-2010, 04:28 PM
problem solved, very easy (and free fix) just add zip ties
Rear washer fix - Ford Truck Enthusiasts Forums
Tho I hate messing with trim, buttons and felxing the roof liner I guess it is better than having fluid leak in the cab....
Old 02-03-2010, 05:21 PM
nice find ... thanks for the info man
Old 02-17-2010, 04:22 PM
My 01 expedition did the same theing. Right front kick panel, the hose had come loose at a fitting.
