Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 Ford Excursion Forum
99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only.
Old 11-07-2009, 08:26 AM
akexc akexc is offline
Slip fit? wheel hub
I'm trying to pull the wheel bearing hub from the front of an '03 Exc. Ford says it's a "slip fit". I have the snap ring off and have tried a large pulley puller, but this think acts like it's rusted on.
Am I missing something? Anyone experienced this?
Old 11-07-2009, 09:31 AM
elm302 elm302 is offline
just did mine yesterday and i just pulled the snap ring and the four bolts on the back and my rotor and caliper and went to wiggling and tapping the back of the assembly with a hammer and used plenty of wd 40
Old 11-07-2009, 09:34 AM
Tony V Tony V is offline
Sweet Diesel Smell
Mine came off after the 4 bolts was takin out. maybe a little no blow hammer would help ya.
Old 11-09-2009, 12:39 PM
Got it off. Just wanted to make sure I wasn't missing something before I brought out the bigger hammer.
Thanks.
Old 11-11-2009, 12:18 AM
adfields adfields is offline
It's called a "unit bearing" and not serviceable just so you know. I know you have it off but here is my method since I live in the great white north, home of the snow, and land of rust.
1. First pull the snap ring from the axle and the 4 nuts inside the knuckle.
2. Gently bend the tab that covers the wheel speed sensor up and remove the sensor.
3. There is a spot behind that where the dust cover makes a void between the flange and the knuckle that I tap a small chisel into that gets it started.
4. Once it’s started I move the chisel down one way, then the other to pry it out as straight as I can.
When I install I clean all the rust and grease the heck out of the stud holes with white lithium grease so they don’t rust up and stick again for next time.
Old 11-22-2009, 06:17 PM
strester strester is offline
Ok, I know there are other post. But my auto hubs, lock some times and other not. If if mess with the defrost they will lock in 4 out of 5 times. Is it the oring on the hub or other issue.
