Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 Ford Excursion Forum
99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only.
Old 10-26-2009, 11:05 AM
RustyNCA RustyNCA is offline
Where to mount a brake controller?
So I just purchased this 03 7.3l Ex. I need to mount a brake controller in it, and would like to do it without drilling holes in the dash. Anyone come up with a trick way to do that? Found the factory wiring harness never opened in the center console for the controller
Took these photos with my cell phone, usually does better than this.
Here she is with the old Suburban she is replacing.
Got to the race track, unhitched the trailer and noticed the guy from Carson two pits over has a twin...
Old 10-26-2009, 11:26 AM
03-blue-Powerstroke 03-blue-Powerstroke is offline
Almost Deer Season!
Nice truck! I don't think you will get away with not drilling any holes. I put mine in the fuse cover as you can see in this picture. I can get a better picture if you want.
Old 10-26-2009, 11:29 AM
southern7.3 southern7.3 is offline
Powerstroke Fanatic
I put mine under the little pocket in the dash, right where the cb is in the above post. My cb is under the ashtray.
Old 10-27-2009, 08:32 AM
Thanks for the help. Hadn't thought about putting my CB in it.
What is the black unit attached to the CB? It's not an amplifier for the CB is it?
Old 10-27-2009, 08:43 AM
cliford cliford is offline
i have mine mounted on the floor right infront of my 4X4 shifter. in 03-blue-powerstoke it would be right infront of his flashlight towards the engine.
Old 10-27-2009, 08:45 AM
SuperCrutyPS SuperCrutyPS is offline
I mounted mine down at the bottom of the dash, below that catch-all slot. The trucks controller plug is right behind there. Convenient for me to get to.
Old 10-27-2009, 08:56 AM
Almost Deer Season!
Its a Uniden police scanner .
Old 10-27-2009, 09:04 AM
Raul@Stealth Automotive Raul@Stealth Automotive is online now
thats about where mine is mounted but i have the F 650 dash mod and it has a perfect place to mount down there...
Old 10-27-2009, 09:33 AM
01excursion7.3 01excursion7.3 is offline
I've seen someone cut the trash bag holder up and make an insert there for the brake controller. Looked like a pretty slick setup. Personally, I don't haul trailers too often. So I just pull my cup holder out and set the controller in the hole. Worked out, threw the cup holder back in, and all is good now. No holes.
Old 10-27-2009, 09:47 AM
Powerstroke Fanatic
Thats where mine is..
How does that police scanner work out for you. You can just hear what they are saying like a regular house hold scanner?
