cons: say good by to your transmission and around $3-5k of your hard earned money.
order a ts 6 position chip or a php hydra programmer from corey from cncfabrication on the forums. He'll set you up with customized tunes for your trucks mods, driving style and preference and you wont need to worry about your trans every time you drive.
I would recommend an edge insight monitor though... esp for egts and trans temp.
edge makes good power but its claims of tuning the transmission were well over proven incorrect. You'll notice they never have an edgeproducts rep trying to counter these post and that should tell you something.
The TS chip can be ran on the Excursions with PATS, but you will get the security light flashing on your dash all the time. The PHP Hydra is PATS friendly and has the option to enable or disable it.
Just dont be led onto the cheap TS chips online that come with crappy canned tunes. Its quite normal for those that buy them to have harsh trans shifting. Here's a couple links below to what I would recommend and the Hydra is by far the better choice. But both come with PHP tuning.
Ya, I'm trying to figure out what exactly I want to do. I have tried the modified tunes but they seem like they shift way to soft, and for some reason produce a ton of smoke. It shifts perfect as long as i have a load.... Just an interesting difference. I think i'm going to try to pull the trans command and see what it changes. Need that bypass plug
I'll put in another good word for the Hydra Chip. I first tried the ts and wasn't all that happy with it, the Hydra canned tunes run cleaner and cooler. Plus there's plenty of choices.
Sent from my SAMSUNG-SM-G890A using Tapatalk
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
