EGT placement - Ford Powerstroke Diesel Forum
99-03 Ford Excursion Forum This forum is for topics relating to the Ford Excursion only.
Old 02-18-2007, 06:31 AM
EGT placement
Should an egt probe be placed in my downpipe or in the manifold?
NeillBarber
Old 02-18-2007, 06:40 AM
duct tape & zip ties
NeillBarber
I suggest the manifold as it gives you more accurate reading. Mine is tapped into the driverside exhaust manifold.
If you do put it in the manifold use grease to catch as much of the metal shavings as possible then use a shop vac and suck out the other metal shavings that are still in the exhaust manifold. That is how I did mine and it works great.
Old 02-18-2007, 06:41 AM
NeillBarber
The exhaust manifold gives you more accurate reading.
Old 02-18-2007, 11:21 AM
im fat and ugly
EGT probe placement
