99 f350 no speedo ABS light on - Ford Powerstroke Diesel Forum
post #1 of 10 Old 06-09-2009, 08:19 PM Thread Starter
JMaN06's Avatar
i have a 99 f350 7.3 4x4 manual tranny. the speedometer does not work n the abs light is on. ive heard they are related. im more worried about the speedo getting fixed..hopefully asap. so far we"ve changed the abs sensor on top of the rear differential. nothing happened.... what else can be done or checked??
thanks
JMaN06 is offline
post #2 of 10 Old 06-14-2009, 06:40 PM
henrymiller1's Avatar
I had same trouble w/ my 2000 250. There are two abs sensors attached up front. I had to replace my hub assembly and new sensor came with it. Still had light on. I replaced sensor on rear and all troubles went away. I'm sure you can just replace the sensors w/o doing the assembly. Good luck.
henrymiller1 is offline
post #3 of 10 Old 07-09-2009, 08:22 PM
tbogh's Avatar
i have the same issue on my 99 f250, abs light on, and speedo only works if i go over 30. i only have abs in the rear (i think), so would the only sensor i should be concerned with would be the one on top of the rear diff?
thanks,
travis
2003 f250 cc sb, 6.0l psd, 4x4, afe intake, straight pipe
1999 f250 ec sb, 7.3l psd, 4x4, tymar intake, striaght pipe, sct excal 2
tbogh is offline
post #4 of 10 Old 07-10-2009, 01:37 PM
Had same problem 3 weeks ago it is the abs sensor on the rear dif. twenty dollar fix.
Mike1999 is offline
post #5 of 10 Old 07-12-2009, 07:09 AM
Type 2 Sniffer's Avatar
With the speedo going out, it is probably the rear. Luckily that is the cheap one ($18 I think). You can have a good scanner read that ABS codes and figure out just which one is giving you fits, but I would be willing to bet 24 pack, it is the rear one.
Si vis pacem, para bellum
2002 F-250 Lariat
7.3L Powerstroke: Zoodad Mod, Foil Delete, NAPA Intake, MBRP 4", ISSPRO 3-gauge
Type 2 Sniffer is offline
post #6 of 10 Old 07-12-2009, 08:01 AM
tbogh's Avatar
looks like i owe you a case. it was just the speed sensor on top of the rear diff. 15 bucks later, problem solved. thanks for all the help.
thanks,
travis
tbogh is offline
post #7 of 10 Old 07-14-2009, 10:59 AM
thanks,
travis
Glad it worked
2002 F-250 Lariat
post #8 of 10 Old 07-17-2009, 04:13 AM
Yup had the same prob. with my 99 sensor on diff. 5 minutes later and 7 bucks(own a repair shop get at cost).
-Mike
02 Lariat CC SB 7.3 8" lift 35.5x12.5.18
Rough Country Dual Shocks on all 4's
Dealer of:
Kennesaw Mountain Accessories
Mental Midget is offline
post #9 of 10 Old 07-22-2009, 07:31 AM
I had the same exact problem on my early 99 F350 4x4 with a manual tranny. the speedo and cruise ,stopped working and the ABS light went on. I could reset the cruise control but the ABS light stayed on. The speedo would bounce all over. I was thinking that it might have spomething to do with the F5 chips I recently installed. Glad I read this. Saved me a lot of looking.
COP-OUT is offline
post #10 of 10 Old 08-05-2015, 05:29 PM
F350 diesel automatic, sits at 100, when I start driving goes to 75 and stays. Changed the rear sensor, does the same thing and now the abs light is on. Not a mechanic so please dumb it down for me. The only way I found out about the vss was this site and YouTube. Thanks in advance.
Ballpaul11 is offline
