no wait to start light - Ford Powerstroke Diesel Forum
Old 01-30-2007, 06:14 PM
Moderator
Send a message via Yahoo to 00powerstrokin
my buddy has a 99 psd with 6 speed and predator tuner. ran fine yesterday. he went out to start it today and he has no wait to start light and it won't start. predator won't recognize the vehicle. what do you guys think?
Old 01-31-2007, 03:07 AM
Moderator
i thought u guys wold be all over this one!
Old 01-31-2007, 03:30 AM
ADMIN AND TECH
find blown fuse for fuel heater sounds like heater is shorted in filter housing and blown fuse , which will cause concern you are referring to
Old 01-31-2007, 03:31 AM
ADMIN AND TECH
if it is blown ,unhook white conector on back of filter housing ,and everything should work fine ,dont have to have fuel heater
Old 01-31-2007, 02:04 PM
Moderator
thats what it was a bad fuel heater. thanks for your help.
Old 10-24-2007, 07:05 PM
Send a message via Yahoo to mufassa2u
i want to bump this. i have the exact same problem,however i have no blown fuses and my transfer pump is not getting any power to it...i have no "Wait to start"...just cranks and no start now..i really really miss my truck and it just did this today..please help!!!...if i gotta be stuck id rather be in the mud..
Old 10-25-2007, 02:47 AM
ADMIN AND TECH
if you dont have a wait to start light , the pcm isnt getting power , you may want to look at those fuses again, the wait to start light is controlled only by the pcm ,
Old 10-25-2007, 04:02 AM
I had same problem,found a bad relay under hood.
Old 10-26-2007, 03:28 PM
ok...i found the bad pcm relay...replaced it and it ran till i got home..on the way home service engine light came on with water in fuel and blew the new relay again....i replaced the fuel filter sbout a week ago...do you guys think i may have grounded out the heater in the bowl??...thank you guys for the awsome input...im a diehard ford super duty fan and im not givin up on my truck.
Old 10-26-2007, 04:51 PM
ADMIN AND TECH
i still think that you definitly have a fuel heater issue yes
