Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems
  #11 (permalink)
Old 10-28-2007, 09:58 AM
mufassa2u mufassa2u is offline
Send a message via Yahoo to mufassa2u
ok....its the fuel heater...ii reset the pcm and unplugged the heater and runs fine...so my question is...should i buy from a cheap parts store or is it worth it to buy dealer part ....and how hard is this to change?
  #12 (permalink)
Old 10-28-2007, 10:53 AM
SCUFFY828 SCUFFY828 is offline
FORD TECH AND ADMIN ....
you dont even need the fuel heater , if its running drive it , you cant just buy the heater have to buy the whole fuel filter housing assembly , its 500.00 , drive it
  #13 (permalink)
Old 10-28-2007, 04:21 PM
unplugged heater and runs fine for now...hopefully it gets me to work all week till i can get a new one..
  #14 (permalink)
Old 10-28-2007, 04:23 PM
oops..i already said that...well its coming on winter time will this cause me trouble in 0 degree weather?
  #15 (permalink)
Old 11-08-2007, 06:48 PM
well ive still got a problem with this...so i bit the bullet and took it to the dealer,they told me my chip went bad and has possibly damaged my pcm...took out the chip and it runs...but less power...but dont know if its actually fixed cause it would run for a day and next morning it would have noo wait to start light and wouldnt start...try it in the evening and it would work again...so after taking out the chip have to just drive it and see if it messes up again..they also told me i have 3 weak injecters...but i ran a test with a solus OBD II and it checked the injecters and they tested fine...anyone have any suggestions as to what chip i should get to replace the bad one???
  #16 (permalink)
Old 11-16-2007, 10:13 AM
paulboydencustoms paulboydencustoms is offline
BUMP!!!!!!!!!
help my truck is doing the same, but i disconnected the fuel heater, checked all fuses and relays, still no wait to start light...the PCM is warm and the truck is not even running. I disconnected all 5v sensors and still nothing, preadator wont recognize truck, truck has 468000 miles, is it tome for a new PCM? if so is my program that was in the old PCM lost?
  #17 (permalink)
Old 11-16-2007, 05:33 PM
bump
  #18 (permalink)
Old 11-16-2007, 11:17 PM
well i bought a programmer rather than a chip and i gotta tell ya i did something right,truck runs hella better than it did when i bought it...smartchips 1705...no more pcm issues.....if your truck has this same issue take chip out and drive it to get a new one...if its programmed and its bad...you may need a new pcm..or try taking the programmer and reverting program to stock...
  #19 (permalink)
Old 11-17-2007, 08:11 AM
my programmer wont recognize the truck right now, thats why im worried that my program may be lost in the bad PCM, i dont have a chip, just the programmer and its diablo sport predator
  #20 (permalink)
Old 03-29-2008, 04:48 PM
250stroke 250stroke is offline
re it worked
Originally Posted by SCUFFY828 View Post
if it is blown ,unhook white conector on back of filter housing ,and everything should work fine ,dont have to have fuel heater
that was it now what do i need to replace so i can plug the wire back in thanks for advice
