Fuel leak
ive put new o-rings from ford on the filter/seperator drain valve and the fuel heater o-rings but it is still leaking, where are some usual spots other than those that leak fuel on or around the hpop
Fuel leak
On the 7.3's it is common for the metal fuel line for the pass side head to wear a hole under the glow plug relay bracket and back by the turbo pedistal.
Dag on- another leak!
If you need a hand lemme know! |
When you did the O-rings on the separator, did you take the top off the filter bowl and remove the filter at all? There're two rings on that filter assembly that can get misplaced and leak like a banshee.
