Small problem, Speedo quits working
I am new to this forum as well as being new to the Blue oval group. I have to get one thing of my chest first I was a tried and true Chevy lover, Twenty years of nothing but G.M. I race on the weekends and have a high cube van with a big block Chevy BUILT to the Hilt for towing. I tow a very heavy 38’ enclosed trailer, the problem with this setup is that by the time I towed to the track I was flat a$$ wore out from the trip, problems noted: top speed was only 60 MPH you could go faster but the engine was turning so hard you may end up with rods in your lap. Ever time a semi past you he would first push you to the right then once he got to certain point on the van he would start to suck you towards him. I had all kinds of stabilizers, sway controls and load levers on this nightmare. (It was unsafe). Fuel economy was about 5- 6 MPG. I wanted a newer (used) vehicle and started talking with some diesel guys and they talked me into looking at that venue. My brother bought a new Duramax and let me use it too pull to a race; “I loved it”. So I started looking for a used Duramax because the racing fund eats up so much money that I could not afford new. I ran into two huge problems looking for a G.M. 1. The Chevrolets are selling for about $5,000 more than a Ford or Dodge. 2. The Fords look so much nicer than the G.M’s I started looking at the Fords. I like the Cummings but hate the rust problems the Dodge has so that was out. Now to the good part I final settled on a 1999 F350 4 door dually with automatic and 4.10 gears because it was in excellent shape and was in my price range. I installed the edge with juice to help mileage and the best MPG to date is 20.5 (not pulling a trailer of course). This truck drives like it is brand new will yank the trailer down the road like nothing is behind it, will go 70 Mph on the interstate with one hand on the wheel. I will definitely look at Ford again when I update. I know I will have problems with the truck because of the age but I can have a few problems for what I paid for this truck and still come out way ahead. I keep a spare CPS in the glove box for the dreaded 10-minute pit stop. My father in-law has a new Duramax that was in the shop for injector issues and need to borrow the Ford to move his 44’ Montana trailer. He was very impressed with the power moreover the handling, it didn’t move the F350 around like it did his Chevy, to be fair his Duramax is complete stock and not chipped like mine.
Now to the problem: Once every month or so the speedometer will drop out and the O/D light will flash. The last time it did this I drove an extra 10 miles to see if the speedometer would start working again it did not until I stopped the truck on a side road shut it off and let it set for 1 minute key off and restarted it. This fixed the problem, why did I have to shut off the truck to get this to work again. If it was the sender in the rear differential wouldn’t it start to work again after getting the correct impulse signal from the sensor? Thanks for the help, and before I get hate mail from the other two makes, I do like things about each brand. Can I place my order for a Cummings engine with a Ford body and rear differential and Allison transmission?
LLB
