Glowplug's wear out??? - Ford Powerstroke Diesel Forum
post #1 of 14 Old 01-25-2007, 11:02 AM Thread Starter
Send a message via AIM to crapzuk
Buddy of mine has a 2001 PSD, he's saying he has to cycle the key back and forth a few times (as if to get the plugs hot enough) to get it to start. Do glowplugs wear out over time? Could this be his problem??
Jason
crapzuk is offline
post #2 of 14 Old 01-25-2007, 11:06 AM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
how cold is it there now
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #3 of 14 Old 01-25-2007, 11:45 AM
straycat's Avatar
Could be a harness/connection issue as well. Gets pretty cold up here, and I don't plug in at night and mine fires up first shot, every time.
Gord.
SKILLFULLY DISGISED AS A RESPONSABLE ADULT.
99.5 F350, CC, LB, DRW.
7.3 AUTO 4.10s
AUTOMETER C2s EGT, TRANS, BOOST, OIL, FUEL PRES
ATS, WW, SSHPX, B ANNIH.
DP 6P 140EX.
AFE MAG F STG 2.
MAGNAFLOW 4'' TURBO BACK DUALS.
US GEAR SUPER D-CELERATOR
500LTR FUEL TANK
BILLET GRILL
ALARM & REM START/ ELC BAT DISC.
CB, SAT, GPS, PANASONIC CD, 5th WHL
35' GOLDEN FALCON
Been a mod longer than TJ hahaha
straycat is offline
post #4 of 14 Old 01-25-2007, 12:38 PM Thread Starter
It happens anytime the temp drops below 5o degrees. Plugging it in alliviates the problem, BTW, this is a friends truck, my 03 fires off first shot everytime and I don't have to go through this mess. He has to cycle it about 7 or 8 times and then when it fires off there's alot of white smoke (prolly just the cold causing that though). He says it just started doing it this winter....
crapzuk is offline
post #5 of 14 Old 01-25-2007, 12:42 PM
ADMIN AND TECH
SCUFFY828's Avatar
cycling the ignition switch doesnt do any good ,the light and actual glow plug on time are two different things ,alot of people dont know that , the light only stays on for 10 seconds , the glow plug relay controlled by the pcm can stay on for up to 90 seconds even though light is off ,glow plugs generally dont go bad in 99 -03 models mostly just the relay
ITS STOCK
SCUFFY828 is offline
post #6 of 14 Old 01-25-2007, 12:46 PM
cblackb's Avatar
Well, there are many posts on here about diagnosing glow-plug problems. One thing that can happen is that the glow-plugs don't necessarily "wear-out" but they get covered with carbon on the ends. When carbon gets built up too thick it limits the amount of heat that is disappated from the plug and therefore it's not as effective. If you remove a glow-plug and it won't come out of the hole due to carbon build up, don't force it, soak it with penetrating oil and dissolve the carbon.
2000 F-250 XLT PSD Auto Super Cab SB 4x4
Magnaflow 4" straight-piped into duals
Eclipse Sport Trucks Body and Interior Conversion
Tinted Glass
Zoodad Mod
Diablosport Chip (don't know HP)
Foil Delete Mod
DIY/6637 Intake Mod
Oilguard Bypass Oil Filtration System
CCV Mod
HPX Mod
Mag-Hytec Everything
BTS Valve Body
Cobra 29 LTD CB Radio
IAH Delete
cblackb is offline
post #7 of 14 Old 01-25-2007, 02:55 PM Thread Starter
If that's true than how is it that when my trucks just been turned off and I start it back the light goes off quickly?
crapzuk is offline
post #8 of 14 Old 01-25-2007, 03:11 PM
JUGGERNAUT's Avatar
My 99 glow plugs went bad 2 years ago.
I miss my truck!!! But I love this
JUGGERNAUT is offline
post #9 of 14 Old 01-25-2007, 03:14 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
The light is also related to fuel pressure needed to start if the fuel is there it is not on as long
Email:
Edge Insight CTS
Coolant filter
Dave is offline
post #10 of 14 Old 01-25-2007, 06:00 PM
Lord Tauk's Avatar
I heard pouring some Seafoam in the filter bowl will clean out the carbon on the glowplugs, along with giving the injectors a cleaning.
Dumping some in the tank will probably give the same result over the course of the whole tank of fuel.
Lord Tauk is offline
