Changing IPR. - Ford Powerstroke Diesel Forum
post #1 of 12 Old 05-06-2009, 04:35 PM Thread Starter
PMR = JUNK
Jake's Avatar
Quoted: 6 Post(s)
Question Changing IPR.
How do you change the IPR. Is it pretty simple? Will an IPR off a '97 work in my 2000?
BPS President
2000 F-250, forged rods, 38r turbo, BTS trans, hutch mod, TW tuning and Bad Night Special 50 horse Caterpillar injectors
Originally Posted by alberta 7.3 View Post
Yeah, I'd probably feel a bit drained after firing twice in rapid succession.
Jake is offline
post #2 of 12 Old 05-06-2009, 05:16 PM Thread Starter
PMR = JUNK
Jake's Avatar
Quoted: 6 Post(s)
Common, this is an easy answer for someone.
BPS President
Jake is offline
post #3 of 12 Old 05-06-2009, 05:21 PM
Too cool for school
taylorking's Avatar
Feedback Score: 3 reviews
Send a message via AIM to taylorking Send a message via Yahoo to taylorking
you changing the whole thing or just putting new o-rings on it?
Typical cummins owner.
taylorking is offline
post #4 of 12 Old 05-06-2009, 05:23 PM
FordCowboy's Avatar
96 up should work on your truck. 94-95 are slightly different but I think they might work, but never tried. This link should give you all the info. Where it says to make a special tool, you don't really need to unless you are bored. I was able to put the socket on a breaker bar, and it fit all the way in, some people said you can't get the breaker bar all the way on so it may depend on what socket you have. Mine was from Sears, a Crapsman. To drain the HPOP i bought a cheapo siphon from Harbor Freight and put a catch bottle on the ground and ran the hose down the engine compartment. I still lost some oil in the valley, but I put a bunch of paper towels in and I was fine.
New Page 0
Early 99 Powerstroke
Crew Cab Short Bed Lariat 4x4
SCT Livewire w/ various custom tunes
AFE stage 2
Super 66 Turbo
4" straight pipe
Modded IDM
Automatic trans: PI Converter, tugger kit
Leveling Kit w/ 35's
FordCowboy is offline
post #5 of 12 Old 05-06-2009, 05:27 PM
cchase's Avatar
Jake if your any good you can change it in 5 minutes. I think its a 1 1/4 socket. just take the first bolt off, and then take off the wires, then put the big socket it on.
On vacation from a truck for a year or...
Looking at 6.4s Moving in a few months then hopefully buying my dream truck!!!
Driving an Audi till then...
but at work I drive
16 E-450s 7.3 powerstroke Ambulances
7 Duramaxes
1 GMC Kodiak Ambulance
NO CUMMINS.....
cchase is offline
post #6 of 12 Old 05-06-2009, 05:38 PM Thread Starter
PMR = JUNK
Jake's Avatar
Quoted: 6 Post(s)
I think i might have a problem with mine, so i wanna test it with a known good one out of Tylers truck, his is a '97, thats why i asked specifically that year.
New Page 0
Thanks, ill check that out.
Alrighty, thanks.
Kinda feel like a for this but does anyone got any pics of it on the truck? Trust me, im not a mechanical retard, ive done some major repairs before, just wanna make sure cause i'll be doin this 4 hours from home and i don't wanna F anything up.
BPS President
Jake is offline
post #7 of 12 Old 05-06-2009, 05:51 PM
FordCowboy's Avatar
No pictures but you can't miss it. To the drivers side of the fuel bowl it is really the only thing down there with a plug going to it. The plug for your fuel heater, and ICP sensor branch off of the same harness as the IPR so if you follow those wires it can help you find it. Not much to screw up. A little tin nut to take off first, then slide the spacer and the solenoid off, then you can get to the big nut to get the whole thing off. It's tight and not much room to swing the breaker bar, so just make sure it is all the way on so you don't strip it. Other than that, no little pieces to lose or anything.
AFE stage 2
Super 66 Turbo
4" straight pipe
Modded IDM
post #8 of 12 Old 05-06-2009, 05:54 PM
FordCowboy's Avatar
Oh the plug going into the solenoid has one of those little rubber gasket dealies to seal it up, I lost that in the valley and had to dig through all the sludge to get it and then had to clean it off good, so just watch for that.
AFE stage 2
Super 66 Turbo
4" straight pipe
Modded IDM
post #9 of 12 Old 05-06-2009, 06:28 PM Thread Starter
PMR = JUNK
Jake's Avatar
Quoted: 6 Post(s)
Are there any O rings or anything that i need to replace when i switch them?
BPS President
Jake is offline
post #10 of 12 Old 05-06-2009, 06:34 PM
FordCowboy's Avatar
The only o-rings are on the IPR itself, so as long as you are taking his off his truck and it wasn't leaking you should be fine. If it is one he just has laying around, double check it to make sure they are on it, it should match up with yours, but there is one at the end of the threaded part to seal the threads up and one little one towards the end of the IPR that sits in the HPOP you should be able to see the recess if it is missing, but those are the only two.
If you are thinking there is a problem with yours and you know for certain his works I would use his solenoid thing too, just to make sure your problem isn't with that.
AFE stage 2
Super 66 Turbo
4" straight pipe
Modded IDM
