HELP!! Replaced cam sensor and still nothing
Hello,
A few days ago I ran into the store to get some stuff and when I cam back out the truck had died. After about 10 minutes it started again, but died on the way home. I put a scanner on it after I towed it back and it had all the standard cam sensor codes as well as an EGR code. I just replaced the cam sensor and it will start, but only after hard cranking for about 10 seconds, it runs starts to shutter, then dies again. Any ideas? |
TRY CLEaning the egr
I would check the IRP valve (injector pressure regulator)
this is in the 7.3 section.. do you have a 7.3 cause if you do there is no egr on it
This is a 2 year old thread.
hahah I didnt notice that
i just saw the post above mine was from today
