Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems
Old 04-08-2009, 06:13 PM
Removing Turbo-Replacing up-pipes
Hey guys iam going to be removing my turbo to replace my up-pipes. Is there anything that I should do when I pull it out? replace anything? any other tips appreciated also has anyone had problems with the manifolds leaking?
Old 04-14-2009, 09:20 AM
no manifold leak but u can get every thing ceramic coated!!!!
Old 04-14-2009, 09:39 AM
International Threat
Why pull the turbo to do that?
Drop the downpipe and you can get at everything from under the truck with extensions.
Old 04-18-2009, 04:45 PM
cuz iam putting in bellows so I never have to do this again (hopefully)
Old 04-18-2009, 05:08 PM
I just did my turbo, up pipes and pedistal. Even with my turbo out I did everything for the up pipes from underneath. No reason to remove the turbo for this job. I didn't take my downpipe out either (welded all the way back on mine). Might help to loosen it at the turbo so it can move around a bit and if you can take your downpipe out then it should be "cake". I would say 3-4 hours if you are familiar with wrenching on vehicles, 6 if you aren't. Wobbles/universals with long extensions are your friend. Good luck and post back if you have any questions.
-Aaron
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.3.2
