ecu replacement
Ok if any of you have read my old last threads i need to get an ecu, I got the code off of the current one and found a couple ecu's but once installed do they have to be reprogrammed by the dealer if i get the correct ecu? Or can i just pop it in and go? Because if i remember correctly some older fords need to be reprogrammed.
Thanks, Dustin |
Come on people, does anybody know?
As far as I know slow, Its a pop in Item if it's the same code as your old one, You can also send it in to DP and get it tuned as well.
Sorry, just saw the post.-- Good luck. ---Gord. |
