Oil Leak. Rear Main? - Ford Powerstroke Diesel Forum
post #1 of 31 Old 03-20-2009, 03:36 PM Thread Starter
Powerstroke W/smoke's Avatar
So I washed my truck yesterday and when i got home I now have a severe oil leak coming from that weird nipple thing that is where the motor and transmission connect. it only leaks when the truck is running, and it leaks very bad. I'm thinking rear main seal...any suggestions or ideas? thanks in advance.
So far I've drained my oil to a mid dipstick level and still having same issue.
UPDATEkay so I looked around and there is fresh oil in the valley...
Sold!2001 F-350Lariat Lifted 7.3L CC, 5" Straight Pipe, DIY Intake, Foil-Delete, 6 pos chip, CCV Bypass, 37" Toyo MT, Gauges, Blacked out, 07 Harley Front-End.
SOLD!2006 F-250Amarillo 6.0L CC, 4" Straight Pipe, SCT-II
STOLEN ,2001 F-350Lariat 7.3L CC, 6pos chip, 4" Banks Straight-Pipe, Banks Comp Wheel, Custom Lighting, Foil-Delete, Intake.
Powerstroke W/smoke is offline
post #2 of 31 Old 03-20-2009, 03:47 PM
Ryan Rønning's Avatar
Quoted: 6 Post(s)
What weird nipple?
9 times out of 10 if there is oil coming from the back of the engine it is coming from the turbo pedistal. Get an inspection mirror and take a look back there!
Project Frankenstein
1997 Ford F-350, Dually conversion, Cobra 29 LX CB, 12000 watt converter, All LED lights, PHP Hydra, 4" DP, Napa Intake, coolant filter, 140cc AD Injectors and lots of running lights.
Originally Posted by XPLOSIV View Post
Thanks. I'll give er a good wackin in the morning.
Ryan Rønning is offline
post #3 of 31 Old 03-20-2009, 03:47 PM
Broncoguy's Avatar
Oil Leak
Did you pressure wash the engine too?
It isn't all that common for a rear main leak on a 7.3. Have a look in the valley on top of the engine. There is a drain hole at the rear of the valley that lets any leak from the top of the engine drain down the back of the block and mimick a rear main leak.
I would bet the leak is up top somewhere, maybe a turbo pedestal o-ring or a leaking HPOP.
Let us know what you find, and we can go from there.
1999.5 F350
4" Straight Pipe / Gauges (Pyro, Boost)
Wicked Wheel / Wg delete / Boost fooler
Tymar intake / Zoodad Mod / NChornet CCV mod
Hpx Crossover / Fuel CCK / ITP prepump tank mod
FPR Shim w/ underhood gauge
AIH Delete / Non Ebpv pedestal w/ valve delete
TW 6 position chip (will never own another canned toon)
3.73's / 6 speed manual 4x4
Still messin with it
Broncoguy is offline
post #4 of 31 Old 03-20-2009, 04:29 PM Thread Starter
okay so I looked around and there is fresh oil in the valley...
post #5 of 31 Old 03-20-2009, 04:33 PM Thread Starter
MOD! Can a mod please change the title from what it is now to "Oil Leak From Vally" please? thanks if you can
post #6 of 31 Old 03-20-2009, 04:44 PM
Quoted: 6 Post(s)
Have you determined if it is comming from the turbo or the HPOP?
post #7 of 31 Old 03-20-2009, 04:50 PM Thread Starter
negative. i'm still looking around the engine area to find the cause, but there is so many things in the way.
post #8 of 31 Old 03-20-2009, 04:53 PM
My 02 had a similar problem with the previous owner and it turned out to be the High side oil line. I'm not to sure what that means but it's what the paper work says.
2005F250 is offline
post #9 of 31 Old 03-20-2009, 05:02 PM Thread Starter
Update: so i removed the cover for the fuel filter and the thing under that looks as if to be the cause of the oil.. not 100% sure yet. I'm familiar with the 6.0 motor because of catastrophic motor failure but not so much with the 7.3, so is what i'm describing my HPOP?
post #10 of 31 Old 03-20-2009, 05:06 PM
Quoted: 6 Post(s)
Are you talking about the big plastic cover or the actual fuel filter lid!
