hydro lock snows boost cooler - Ford Powerstroke Diesel Forum
post #1 of 20 Old 01-07-2007, 03:48 PM Thread Starter
Albie30's Avatar
Send a message via AIM to Albie30 Send a message via Yahoo to Albie30
To everyone out there with a snows boost cooler be warned I parked mine yesterday in my driveway with the nose facing down (like the pic) She is now hydro locked Just poured water and meth into the cylinders So instead for puttin my new turbo on I ve been working on pulling the injectors to get this fixed
2000 F250 cc 4x4 4" lift BFG 315's,,dp tuner Auto Meter gauges, Hybrid 235cc injectors,TN BB turbo,water meth injection,Ragin intake,ITP boost fooler Banks intercooler,big head wastegate,power elbow,torque converter,6.0 tranny cooler,High flow intakes AIH delete air ride air bags,gibson 4" exhaust,zoodad mod, remote start, Pioneer dvd/ navigation Sirrus radio,sun coast tranny ,Bts valve body,H11 s,Engine rebuild .030 over,Fluid Dampner,203 thermostat
425hp 775 Tq
13.9 @ 95 mph
Albie30 is offline
post #2 of 20 Old 01-10-2007, 01:50 PM
smokin dually's Avatar
I' m glad i'm not the only one. I had this to happen twice. I moved the pump to the frame rail and not had it happen anymore.
01 F350 CC Dually 360cc hybrids, S475, Stealth oil kit, Balanced Rotating Assembly, Head Studs, DP Tuner, ATS tranny fixed by BTS
smokin dually is offline
post #3 of 20 Old 01-10-2007, 01:57 PM
HardLuck Case of the Year
Ditty's Avatar
Send a message via AIM to Ditty Send a message via Yahoo to Ditty
Dang! Thanks for the heads-up!!!! I'm thinking of going with Meth after my turbo upgrade sometime in the next year or so. Good Info!!!!
DITTY
Brisco:-White 2000 F-350 PSD CrewCab/SRW/LongBed/4x4/6spd Manual/HUGE Powerstroke.Org Vinals!
Favorite Mods: Baby-seat mod/Girlfriend delete/6pos on Xtreme!
Repairs since bought: both batteries/alternator/3 transmissions/4 clutches/entire front axle/new steering stabilizer/power steering pump
Still broken: cracked windshield/all glowplugs/glowplug relay/4WD still out/trailer harness no power
Current Best: 16.149@84.13MPH (Est.7800lbs)
Ditty is offline
post #4 of 20 Old 01-10-2007, 02:11 PM
<<---"Shadow"---
sea71's Avatar
Does that have anything to do with the pump being at or below the level of the engine? or is it caused by something else? Thanks!
Shane
2011 F250 Crew Cab FX4
STOCK!
sea71 is offline
post #5 of 20 Old 01-10-2007, 02:20 PM
bump78063's Avatar
I have my tank below my injectors and my pump below my tank and my injectors so far so good!!! Thanks for the info I will not park on an incline any more
2003 Ford F-250 6.0
Supercab XLT Shortbed 2WD
Edge Juice W/T Attitude
Edge Evolution
Boost CoolerŪ Stage-2 Diesel w/Hobbs
K&N Air Intake Gen 2
High Idle Mod
Zoodad Mod
Muffler Delete 3.5" Cowboy Cut 4" Tip
Gutted Cat
Yokohama Geolandar AT+ II
Tool Box
Bed Extender
Line-X Bedliner
2 1/2 Inch Daystar Spacer (Front)
All New Fabtech Shocks
Mods to Come: Aftermarket Head Bolts and Gaskets, Stacks, Custom Traction Bars,
bump78063 is offline
post #6 of 20 Old 01-10-2007, 02:22 PM
Ditty's Avatar
I think it is a gravity thing, when the bottle and pump are at a higher level than the injectors. Though I'm not sure....I'm by NO means a smart guy, I just get lucky every now and again.
DITTY
Ditty is offline
post #7 of 20 Old 01-10-2007, 06:30 PM Thread Starter
Albie30's Avatar
It is a gravity thing Without that solenoid or if it sticks open there is nothing to stop the water from duming straight into the cylinder whenever the truck is parked facing down the slope i have the 8 gallon tank mounted in the bed and the pump mounted on the frame rail under the rear drivers door I just changed my oil the day before there went a quick 70 bucks plus whatever else this is gonna cost I am so so not happy
425hp 775 Tq
13.9 @ 95 mph
Albie30 is offline
post #8 of 20 Old 01-10-2007, 07:03 PM
Patrick's Avatar
They just came out with this item. I will try to get ahold of someone to learn more about it, and get it listed on the site.
Snow Performance: Solenoid Upgrade
Legendary
Patrick is offline
post #9 of 20 Old 01-10-2007, 08:43 PM
straycat's Avatar
Sorry to hear that, hope you get it fixed up with a minimum of fuss, thanks for the info.
SKILLFULLY DISGISED AS A RESPONSABLE ADULT.
99.5 F350, CC, LB, DRW.
7.3 AUTO 4.10s
AUTOMETER C2s EGT, TRANS, BOOST, OIL, FUEL PRES
ATS, WW, SSHPX, B ANNIH.
DP 6P 140EX.
AFE MAG F STG 2.
MAGNAFLOW 4'' TURBO BACK DUALS.
US GEAR SUPER D-CELERATOR
500LTR FUEL TANK
BILLET GRILL
ALARM & REM START/ ELC BAT DISC.
CB, SAT, GPS, PANASONIC CD, 5th WHL
35' GOLDEN FALCON
Been a mod longer than TJ hahaha
straycat is offline
post #10 of 20 Old 01-11-2007, 02:31 PM Thread Starter
Albie30's Avatar
I called snow and ordered the soleniod it should be here thurs or fri I hope It was 40 bucks He said he had only heard of this happening once before We know that is not the case This seems to happening quite often I wish I did that right from the start It should be here thurs or fri I hope It looks like I will be able to get it going without tearing everything apart Idrained the oil (not pretty about 2 gallons of water) I was told to spin the motor backwards by hand until it locks up then go back and forth this will open up the exhaust valves and push the water out .What do yall think about trying that I guess I will find out when I get home I want to get it all done this weekend headed to the dunes next week I want to test the new turbo and tranny cooler towing my toy hauler
425hp 775 Tq
13.9 @ 95 mph
Albie30 is offline
