99 F250 Power Stroke Problem Weird Noise? - Ford Powerstroke Diesel Forum
Old 01-06-2007, 10:28 PM
Send a message via MSN to PowerStroker99
Hi Im new at this and i recently purchased a 1999 F250 7.3 Power Stroke. When my truck is idling it sounds like a rubbing noise and when i apply the brakes hard it gets worse. Could this have something to do with the power steering pump? Anything can help Thanks
Old 01-06-2007, 11:28 PM
The Fat Mod
Sounds like that might be it, I bet if you put a new one on, it would help. The harder you press, does it get louder? Also, does it do it while turning the wheel?
By the way,
To POWERSTROKE.ORG
Old 01-07-2007, 07:37 AM
Thanks for the quick reply. Yes the harder i press on the break the louder it gets. Occasionally when i turn you hear a slight rubbing noise.
Old 01-07-2007, 07:45 AM
sounds to me like normal ford powersteering whine. Your truck doesnt use vacume for brake boost, its uses powersteering.....since you are turning and braking at the same time....you are taxing the pump for all its worth. If its just a noise and isnt causing any problems....its actaully kinda normal. Most ford PS pumps make noise...some are just louder than others
Old 01-07-2007, 08:32 AM
So do you think i shouldn't replace it?
Old 01-07-2007, 10:41 AM
if its not giving you any steering problems...its up to you. Its not hurting anything but annoying you......some remans are just as loud as the noisy one you take off...
Old 01-07-2007, 01:31 PM
Yea sometimes it does get alittle annoying i don't think i will replace it unless it goes out. Thanks
