Code p1219 new help - Ford Powerstroke Diesel Forum
post #1 of 12 Old 01-31-2009, 03:49 PM Thread Starter
Code p1219 new help
Hey i need some help i just bought a 2002 f350 2 days ago and the truck already threw a check engine light i came up with p1219 i did some searching and only came up with cid stuck low does anyone know what that means, if this helps the truck just starts to die and then comes right back runs great but just shuts down when driving then fires right back up with no problem
thanks for the help
sgt02Du22 is offline
post #2 of 12 Old 01-31-2009, 04:20 PM
Ryan Rønning's Avatar
Quoted: 6 Post(s)
P1219 - PCM/IDM - CID stuck low - CID circuit short to ground, probably intermittent
This is from AE DTC list. Unfortunately I have know idea what CID is. Someone with more experience is sure to chime in.
CID is cylinder identification. The manual says for 1219 code you need to run a KOEO on demand self test and see what other codes are present. Reading through some of the options it looks like it might turn out to be a short related to the IDM.
Do you have a way to check for any additional codes?
Project Frankenstein
1997 Ford F-350, Dually conversion, Cobra 29 LX CB, 12000 watt converter, All LED lights, PHP Hydra, 4" DP, Napa Intake, coolant filter, 140cc AD Injectors and lots of running lights.
Originally Posted by XPLOSIV View Post
Thanks. I'll give er a good wackin in the morning.
Ryan Rønning is offline
post #3 of 12 Old 01-31-2009, 04:40 PM Thread Starter
my buddy threw his computer on my truck today, and that was the only code that came up, then he did a run check with the computer and nothin came up, but everytime i shut the truck off the check engine light never comes back on. should i run the truck until it throws the code and then drive straight over there to see what other codes are coming up?
post #4 of 12 Old 01-31-2009, 04:46 PM
Quoted: 6 Post(s)
Is the truck running any differently from normal?
post #5 of 12 Old 01-31-2009, 05:31 PM Thread Starter
This is my first diesel and i have only had the truck for a couple days, it seems like it runs great has tons of power, runs clean but just dies out when driving sometimes and when i come to a stop
post #6 of 12 Old 02-01-2009, 06:14 AM Thread Starter
anyone know anything about code p1219 still having the problem.
thanks
post #7 of 12 Old 02-01-2009, 06:26 AM
Quoted: 6 Post(s)
Is your truck a manual or automatic?
When it dies does it kinda buck like a TC trying to lockup?
post #8 of 12 Old 02-01-2009, 06:30 AM Thread Starter
auto, sometimes it bucks when im driving or when you get on it and then other times it just dies
post #9 of 12 Old 02-01-2009, 08:29 AM Thread Starter
any help out there before i spend money at the dealer
post #10 of 12 Old 02-01-2009, 08:37 AM
Cynic
Dirk's Avatar
P1219 - CI- stuck low.
There is a intermittent short (grounding). This a electrical problem and there is no "look here to find the problem". Somewhere in the harness, there is a problem.
This most likely happens when driving. Hit a bump, truck will cut out.
Best Car & Motorcycle Insurance | Auto/Moto Protection Today | FREE Trade-In Quote
Voluntary Banishment: Knowing when to leave.
Total Diesel Performance\Unlimited Diesel Performance\Diesel Innovations\BTS\Terminator Engineering\Swamp's Diesel Performance\Black Widow Diesel\Calvert Racing
Dirk is offline
