2000 f250 7.3 - Ford Powerstroke Diesel Forum
post #1 of 10 Old 06-18-2014, 05:25 AM Thread Starter
2000 f250 7.3
extended cab
i have a truck that randomly shuts off but will immedialty restart no problem. i replaced the cps but because when scanned it was that cirrcuit that came up.
the new cps did not fix the problem.. any ideas?
yourelectrician is offline
post #2 of 10 Old 06-18-2014, 05:39 AM
sbluke55's Avatar
Quoted: 500 Post(s)
Garage
Check to see if cps wiring harness is chaffed and shorting out.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
post #3 of 10 Old 06-18-2014, 06:46 AM Thread Starter
ok i will try that!
post #4 of 10 Old 06-18-2014, 06:52 AM
Winning DUHHH
Young-SC-Owner's Avatar
Quoted: 8 Post(s)
Did you get an oem CPS?
Sent from AutoGuide.com App
99.5 F-350 SRW Short Bed, Ex Cab.
6637
Wicked Wheel'd,
Southbend
Autometer - Boost, Pyro
TW 6 Pos Chip
Water/Meth Inj
Diamond Eye 4" TB
7 year Veteran with SBFD
Airframe and Powerplant Mechanic
Head Marine Technician
Dont Tread on Me
Young-SC-Owner is offline
post #5 of 10 Old 06-18-2014, 07:11 AM Thread Starter
no it was a napa part that i got
post #6 of 10 Old 06-21-2014, 02:45 PM
flippab2580's Avatar
do you have anything plugged into your pcm? chip, etc?
flippab2580 is offline
post #7 of 10 Old 06-21-2014, 02:51 PM Thread Starter
no but it ended up being a nick in one of the wires goin to the sensor . it hasnt hiccuped yet since i addressed it. thx for everyones input!!
post #8 of 10 Old 06-21-2014, 03:44 PM
sbluke55's Avatar
Quoted: 500 Post(s)
Garage
Good deal.
01 f-250, Standard
sbluke55 is offline
post #9 of 10 Old 09-18-2014, 04:15 AM
Hello, i have a 96 f350 crew cab 7.3 chk engine like came on no power ruff idle changed fuel filter no help . Drove trk 45 miles home no power 35 mph max. Found burnt connetor at valve cover. Replaced valve cover gasket and now has slight miss ruff ldle and blue smoke seems to have much more power than before problem but dont know why the smoke and lo rpm hessitation seems to run down the high way great but again whe accelerating blue smoke! Any ideas? Thanks
rob436153 is offline
post #10 of 10 Old 09-18-2014, 04:20 AM
I did replace wiring for fuel injection also
