CCV mod, now bad oil leak. - Ford Powerstroke Diesel Forum
post #1 of 1 Old 06-16-2014, 08:40 AM Thread Starter
recordbreaker5's Avatar
I originally did the CCV mod a couple months ago where it was just venting to to atmosphere underneath the frame rail under the drivers door. Well i have substantial blow by and it was smoking me out so I put a catch can on it yesterday and ran it back to the intake to pull some vacuum. Before and CCV mod, there was ZERO oil leaks from the engine, no small drip, etc. After the venting CCV mod, a small leak began that would drip from the inspection plate. I didn't worry to much to begin with. But now, after adding the catch can on there, a massive oil leak is flowing down the top of the trans. Valley is dry and clean, so not HPOP. Its coming from the pedestal, just not sure where. Mind you, I just put this motor in the truck a couple months back and everything has been resealed with new everything. I initially though ped o-rings but they are brand new and everything was torqued to spec. Is the oil coming out of the EBPV??? If I just ordered a non EBPV and put it on there this should cure my issue correct?
2001 F350 CCLB DRW- Edge Insight CTS, PHP Hydra, 4" MBRP turbo back, AFE Stg 2 XP, Mag-hytech trans pan, Garret Non-EBPV pedestal, Garret Non-EBPV exhaust flange, DS wastegate controller, DS HPOP adapter plate, DS thermostat housing w/ 203*, DS coolant filtration system, DS transmission filtration system, Max-AC assist valve, Tru-cool transmission cooler, DS SS ESOF lines, Bilstein 5100 shocks, Bilstein 5100 steering stabilizer
recordbreaker5 is offline
