Truck idles rough and has check engine light - Ford Powerstroke Diesel Forum
post #1 of 5 Old 06-08-2014, 07:00 PM Thread Starter
chardnay10's Avatar
I have an early 99 and my truck was running fine one second, then next thing you know the service engine light comes on and the motor dies. it wont restart unless i turn ignition off then back on. and starts right back up, now the rough idle is here and light is on and is missing bad. tried a new ipr valve didnt fix it, i checked the icp sensor which isnt it to, another thing i notice is, the colder the oil temp the problems go away then when you go to drive they come back. what could it be
2005 F250 Lariat, SCT X3 with Gearhead tunes, PHP Atlas 40 FICM Tune, 4" Exhaust, K&N Intake, XDP Coolant Filter, EGR Delete, ARP Headstuds with OEM Gaskets, 5w-40 Full Synthetic oil, 8 inch Fabtech 4 link 4.0 Coilover lift. Pioneer deck with 12" Sub, LED Lights all over.
chardnay10 is offline
post #2 of 5 Old 06-08-2014, 07:03 PM
BryceB's Avatar
Quoted: 2 Post(s)
The only true way to know without throwing parts at it is to scan it and get the codes from the computer. If the SES light us on, it's got a code stored. Find someone locally with Auto Enginuity and pay them a 12 pack of good stuff to scan your truck.
2001 Ford F-250 SD CCSB 7.3 PSD - AIS Intake, Zoodad,
MBRP 4" XP Series Exhaust w/ Muffler, HD4R100, 26 row Trans Cooler, Fumoto Valve,
285/75R16E BFG AT KO, Pioneer AVIC-Z130BT Nav, BOYO VLT-422C Back Up Camera,
Scangauge II, Glowshift 3 Gauge Pod (EGT,TFT,Boost), PHP FU Chip, Huskyliners, Huskyliner Mud Flaps, Warn Premium Hubs, Riffraff Boots/Clamps/inserts
Dyno'd at Mo's Speed Shop 11/3/12 - 307rwhp / 651rw ft-lbs <<<--- On PHP 120Race tune
BryceB is offline
post #3 of 5 Old 07-29-2014, 11:34 AM
Hi, did you ever get any ideas about your problem... Im having the same problem.
Engine check light comes on, engine runs really rough, (like a fouled spark in a gas engine) or maybe fouled injector? but the problem cured itself after about 4 miles of chugging along... taking it in to local Ford store, and would like ideas before I go!!
regards,
Dennis/WB6UHQ Los Banos KOA
WB6UHQ is offline
post #4 of 5 Old 07-29-2014, 04:17 PM Thread Starter
chardnay10's Avatar
regards,
it ended up being a loose UVCH
post #5 of 5 Old 08-06-2014, 10:01 AM
I got mine resolved too..ended up being a shorted ICP line into the valve cover.
cost about $400 for one bank and opted to get other bank replaced... found too
that the turbo boot was rotten, and was sucking air... did not find a replacement part and had to go scrounging, and found a used one... 7.3 parts are becoming scarce... going to have to go to aftermarket 7.3 parts, and that's ok with me.. regards,
Dennis
WB6UHQ is offline
