Getting cylinder cont. faults.... - Ford Powerstroke Diesel Forum
post #1 of 5 Old 06-07-2014, 11:11 AM Thread Starter
Doesn't Even Care
HVAC SuperTech's Avatar
Quoted: 69 Post(s)
I noticed while pulling a hill and while leaning on the throttle decently heavy I had a bad shaking and vibration going on. I also have a hunting idle when up to temp...I did a buzz test with no codes. No injector codes were pulled. I did a cylinder contribution test and found I have cylinders 1 and 8 showing fault. Now, is this more of a wiring issue most likely, or is it an injector poppet issue? I thought of just pulling both and sending them to Casserly and have him flow them and see. Its not that bad to pull them. I've had one other injector of this set have the same issue where a poppet came loose and made the truck do same thing. Sticks have about 50k miles on them
Sent from AutoGuide.com App
Nick
E99/CC/Lariat/Factory Wide Body Kit
"The Mistress"
Power Hungry Performance HYDRA Chip
Custom Tuned by Bill@PHP, Tony Wildman@Total Diesel Performance and Lars@Gearhead
D66 w/Dieselsite WW2, Full Force 250/100s, Adrenalin HPOP, Built Trans, Walbro Fuel Pump, S&B Intake, 6" Stacks, Leveling Kit, Eagle Alloy Wheels, 315/75/16 Grabber AT2s & Much More
HVAC SuperTech is offline
post #2 of 5 Old 06-07-2014, 11:29 AM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
I'd pull the valve covers and check the harnesses first.
dhanna6powerstroke is offline
post #3 of 5 Old 06-07-2014, 04:21 PM Thread Starter
Doesn't Even Care
Quoted: 69 Post(s)
Yeah, I'm gonna have to pull covers anyhow. Is there a way to ohm them out so I can rule them out over the injectors?
Nick
"The Mistress"
post #4 of 5 Old 06-07-2014, 04:39 PM
Mod Newbie
Quoted: 20 Post(s)
Just unplug and use a meter to check each wire. Put the negative probe on one end and the positive probe on the other end of the corresponding wire. You're reading should be 0 if it's good. Just check every wire in each connector. Might wiggle the harness when checking each wire just to make sure there isn't a break.
post #5 of 5 Old 06-08-2014, 06:11 AM Thread Starter
Doesn't Even Care
Quoted: 69 Post(s)
OK. Yeah, I thought there might be something to make it more complicated. Haha. I thought that was how you'd do it
Nick
"The Mistress"
